Hey, I've picked up a second hand dry sump kit for a Gtr but wanted the opinion of some guys who already have dry sumps installed.
The seller told me ue was running a vacuum regulator off one of the valve cover breathers. It is a 4 stage peterson pump running all three pick ups to the sump and a head drain to the pan. He said if you dont have a regualtor it will pull too much vacuum and the pistons wont get any oil (rb30, no squirters) This seems odd to me and you wouldnt think it would matter.
So, is anyone running vacuum regulators? How much vacuum do you run? If you dont then what did you do with the valve cover breathers?
https://www.sau.com.au/forums/topic/355747-dry-sump-question/
I have seen the cam cover breathers just blocked off. It would make sense to run a regulator so you can set it to what you want.
BMYHOE are you using the Moroso dry sump tank and breather unit as well? It looks pretty compact.
if you are scavaging from the covers it's probably not a bad idea to regulate the vacuum. they can suck pretty hard. hopefully a few others running dry sump RBs will chime in with their experience. but with it all set-up correctly blow-by will be practically zero.
4 stage pump wont pull enough vacuum to create any dramas with wrist pin lubrication. I would be suprised if you pulled more then 10in/Hg with a totally sealed motor. Typically need atleast 15+ to have any small end lubrication issues. Which usually requires 5, 6 stage or higher pumps to pull that amount.
Weve run ours with and without a regulator and its made no difference.
Best way to check how much is to hook up a vacuum gauge whilst on the dyno and read what it pulls.
so with no blowby does this mean a catch can is not needed? - i would still like to run the catch can cause i got everything to plumb it up. but if it will make more vaccum i obviously wont run it..
r33 racer has given the answer. it's as simple as hooking up a vacuum gauge on the dyno and see what it's pulling from the head. and he's given some figures to go by.
and yeah no need for catch tank. the oil system is working properly and scavenging oil and vapour from the crankcase which comes out the 'breather' with the oil returning to the system.
You still run a breather can from your oil tank otherwise you may have some oil vapour spitting out of the breather line. If you do overfill the oil tank and system you will definitely get some oil spitting out that breather until it finds an equilibrium.
the whole point of a dry sump is to eliminate oil surge issues. so if plumbed up normally its a set and forget affair.
the only extra thing i would install is an electric gear pump plumbed into the oil feed so it cuts in if the belt breaks or for pre-oiling before start up.
You can run an accumulator if you want. It shouldnt be needed, but it does work well for pre oiling and incase something does go wrong you have some limited back up.
In terms of sealing the motor up, its just a matter of making sure any holes are bunged off and everything is siliconed up well with a good sealant.
The only other trick I would recommend is to get two machined discs to go either side of the pump pulley so the belt cant slip off. Also ensure there is something similiar on the crank drive side too. We lost a motor due to the belt coming off at the track when I ran off and some small twigs and stones got up and decided to lodge themselves between the pulley and belt.
Do you ever use an "auto-shut down" or a limp mode when you get no oil pressure?
We have a limp home setup with the autronic if oil pressure isnt within certain parameters it will limit revs to idle only but no shut down. A shut down would be better as it might even save the motor if those conditions come about.
  • 2 months later...
at the moment i'm talking to dailey engineering about building dry sump pan system for rb30 RWD with the pump attached so there's only 3 lines coming off it scavange to tank pressure to pump and pressure to engine and the pan is billet have a look at the vq35 pans also had a chat to ati about building a balancer with a 60 minus 2 crank trigger in it too
http://www.daileyengineering.com/vq_35.htm
and the regulators you were talking about i believe the race v8's run as much vacuum as possible for more HP
http://www.petersonfluidsys.com/engine_breath.html
on my mate's 25/30 we run a 3 stage peterson pump and plumb the cam covers back to the tank with no restriction
in 3 years only problem we had was when the turbo died and we had no screens on the scavenge and the pump ate the ball bearings destroying the rotors $160 later and all fixed
    • Nah, if I need to fit people in a car I'll just use the Mrs car, the MX5 is perfect for what I need as a fun little sports car for fun on the street As for getting in and out of the MX5, I have no issues as I am a short arse who does lots of mobility training 🥷 If anything, I have been looking at Daihatsu Hi-Jets for a work hack, I helped one of my mates move some stuff with one recently that he picked up from Just Jap, it was a little ripper and plenty big enough for what we needed, it would also be super handy for me as I do alot of gardening, and plan on having some veggie patches and native gardens in the place I buy next year when I retire I did alot landscape gardening and growing veggies prior to my current job, and loved it, and that is a hobby that can keep me sane in my retirement, and as such, the little 300kg load capacity would be more than enough for what I need it to move around I have been looking at utes for just this purpose for a while now, and a near new 2024 Hi-Jet can be had for under $30k And I would rather look at a quirky little Hi-Jet than pretty much any other little ute, well, apart from a Brumby, I love the little Brumby, and weirdly have never owned one yet I was going to buy a heap of raffle tickets to try and win the Brumby that MCM built for Subaru Australia, but sadly I totally missed the raffle, I even filled in some form to be told when the raffle started so I could buy tickets, but to my dismay I was never contacted and found out I missed it when I was randomly googling Brumbys last year... #conspiracy  Maybe I should just buy a Brumby for a little "work hack".....LOL I use to be indecisive, but now I'm not sure
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
