1989 NISSAN SKYLINE BNR32
85000KMS
Mechanical:
RB26DETT STANDARD ENGINE
NEW THROTTLE BODY GASKETS & INTAKE GASKETS
NEW GARRET 2X 2860-7 TURBOS (5000KMS)
NEW SARD FUEL REG & GUAGE WITH EARLS BRAIDED LINE (5000KMS)
NEW APEXI POWER FC & BOOST CONTROLLER TO SUIT (5000KMS)
NEW APEXI PFC HAND CONTROLLER (5000KMS)
WALBRO FUEL PUMP IN TANK (5000KMS)
NIC CLUTCHES CLUTCH (NOT SURE OF AGE)
DOES HAVE FRONT CRANK SHAFT OIL LEAK (TINY BUT THEY IS WET OIL)
FRONT & REAR SLOTTED ROTORS
Interior:
COMPLETELY STANDARD BESIDES PFC CONTROLLER
DOES HAVE BUBBLE ON DASH DIRECTLY IN FRONT OF PASSANGER
A/C / HEATER ONLY WORKS ON DEMISTER
SONY EXPLODE HEAD UNIT
HKS TURBO TIMER
Spare parts:
COMES WITH STANDARD COMPUTER, BOOST SOLINOID & FUEL PUMP
AS SPARES
Condition:
CAR IS IN GREAT CONDITION NO DENTS OR MARKS
HAS 4 BRAND NEW TYRES (4000KMS OLD)
18IN RIMS BIG DISH ON REAR
DARK TINT
Price
$14990 ono
GOLD COAST, QUEENSLAND
Contact: PM or call 0408992232 RUSSELL
https://www.sau.com.au/forums/topic/355799-bnr32-gtr-14990-360hpatw/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
