OK, well after much deliberation ::(, the work has begun. The windows got done today, and the Mags go on next Tuesday. Then next is lowering and a white pearl blow over. (Keep it out of the gutter). I will take pics as I go.........I wanna have a sort of progress story of pics lol. I'll get some more pics tonight too! ;D
Here she is to begin with
http://www.skylinesaustralia.com/forums/sh...50&page=1&pp=25
https://www.sau.com.au/forums/topic/35583-its-started/
Keep an eye on the events section for future activities. There are more and more planned for this year. It would be definitely cool to have a skyline wagon come join us. Although it will mean Danny won't be original with the 4 door thing anymore.
:D
https://www.sau.com.au/forums/topic/35583-its-started/#findComment-711891
Oh sorry - Danny (Autotrust) has the only 4 door skyline that comes to any of the meets. If you came he wouldn't have the only one.
snowman..... i guess you haven't been to any of the meets that i've been to then
:slap:
https://www.sau.com.au/forums/topic/35583-its-started/#findComment-712168
there was a dude (maybe another one) next to acsplit who had an r31 at tuesdays meet at sams place with r31 rb26 conversion
insane, very nuts
Yep thats John.. It is going to be a killah when it hits the street.. cant wait.
Autotrust: You said it would be good to see more r31's... We usually have our own cruises and events... maybe we should have a r31club SAU event?
https://www.sau.com.au/forums/topic/35583-its-started/#findComment-712977
Sounds good, after all a Skyline is a Skyline! The more round tail lights the better! :boobies2:
https://www.sau.com.au/forums/topic/35583-its-started/#findComment-712998
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
