Coilovers generally require an engineers certificate to demonstrate that they comply with the Australian Design Rules (ADR's) with regards to suspension travel, ride height, eyebrow height (the height from the centre of the hub to the top of the inner guard), and clearance from rubbing on full lock and full suspension travel. Height adjustable coilovers should be marked across the threads and spring perches so that an inspector (cops or rego) can identify if the heights been raised since the time of last rego inspection (to defect you!). My engineers cert was around $700, but i had a bigger suite of mods than you, think about getting one for peace of mind
All that being said it depends upon whether or not you need to be inspected upon transfer of registration or not. If you don't need a vehicle identity check then your mods won't be seen by the rego inspectors, and if you get a friendly local mechanic you should be alright. The cops around town are a mixed bag, and it depends on when and where you drive your liner and how you do so. What won't help is big chromies or a excessively loud exhaust.
Have no idea about Carbon Bonnets, but I imagine they'd be looking to see you have a 'secondary restraint' meaning that it takes two actions to open the bonnet, the pull cable in the cabin followed by the lifting the catch is ussually enough, if the catch is gone, then bonnet pins are OK (concealed type, not sharp protusion type). But as I said have no idea...
Worth considering also is that Teh Federal Department of Infrastructure and transport (forgotten what they're called these days) is looking at introducing a National Code of Pratice (NCOP) for light vehicle modifications.
Edited by Broken_R31
Just don't have it ridiculously low and I doubt you'll ever have a problem. I've got coilovers in my R33 at the moment, but when I got them fitted I asked the dude to raise the car if he believed that would be more practical lol. Just make sure you're easily over 100mm at the lowest point above ground, and you're sweet. 130mm would be preferable
I've had height adjustable coilovers in my 34 since I've had it. I made the previous owner take it past Dickson before buying it and they had no issue with them. Have been inspected roadside a few times since and never had issues with them either. YMMV.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
