I've noticed lately that there is a fair bit of black smoke comming out of my exhaust when I give my car a hard time, just wondering what the cause may?
Could it be it's running too rich or a more serious problem?
Motor is a croydon built 26 with t88 with full 4" exhaust.
Happens on low and high boost 15 psi & 26 psi.
Any help is greatly appreciated
https://www.sau.com.au/forums/topic/355851-black-exhaust-smoke/
Could just be blowing a bit of build up out.
Or just a bit rich on the tune, which isn't necessarily a problem. I leave a bit of a cloud when on a full throttle tramp.
if you worried, go stick it on a dynoto get things looked at.
or just stop looking in the rear view mirror!
Does it do it on both high and low boost. I have tuned a few cars that ceoydon tuned 1st Nd on power is tuned perfectly bu the cruise tune is crazy overly rich. Sometimes richer than when on full boost. If urs is the same then it would be a build up of fuel and carbon in the cylinder, then when u boot it its cleaning it out.
Check turbo gaskets (if that's the right term) ... guy at the lights had a "blown turbo" which blew black smoke.
Friend had a 300zx (twin turbo) with a f**ked gasket. Put a liquid in as a temp fix and was safe to go until that happiness wore off.
