13.8 - 14.4 is ideal. little under is ok but 12.6 is too low. is that the best you get out of it or does it get better with rpm? were any accesories being run like lights or stereo? when you stop the engine and just have the key on what is the voltage? need to ensure that gauge is reading correctly first then go from there.
  • Like 1
Test it from the battery - in my experience, the MFD reads slightly low (though, even then seems even lower than I'd expect)
Edit: Just went and checked my MFD - reads 14.1V at idle (and 14.3V directly at the battery) - weird - seem to remember it being out by more (i thought 1V) when I first checked ..
Anyway - hopefully that helps; definitely sounds like you have dramas with your alternator if that's the voltage whilst idling/driving...
  • Like 1
No lights or stereo being run, without the engine running voltage is 12.4....Same readings from battery give or take .1... Took it to mechanics said the alternator is running and charging ok :dry: but its down near 12 and should be up near 14
hope u didnt pay him for that advice.. better off taking it to an auto elec, alternator might be on its way out
there is a chance the alternator is ok but the wiring is the problem. check the voltage at the alternator (although i have a feeling that if the earth to the alternator is dicky then it will lower the voltage reading you get there too).
ok im an auto elec...battery volts should be 13.8 - 14.4 with the revs up so the alternator is wroking harder and charging, gauge is always going to get lower as remember there will be a drop is volts in the leads, test the battery with a multimeter and also at the alternator there will be a differents onces again in the cable....if a alternator/ battery is lower then 13.4 running id be getting the alternator rebuild dont go out and buy one cheaper to fix urs
what do u mean how does it cost, to pull one down, clean, sand blast, replace bearing, and any other parts to make it new is cheaper the buying one,
we charge $132 plus parts, take half a day or so to do,
132 for half day is cheap :whistling:
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
