13.8 - 14.4 is ideal. little under is ok but 12.6 is too low. is that the best you get out of it or does it get better with rpm? were any accesories being run like lights or stereo? when you stop the engine and just have the key on what is the voltage? need to ensure that gauge is reading correctly first then go from there.
  • Like 1
Test it from the battery - in my experience, the MFD reads slightly low (though, even then seems even lower than I'd expect)
Edit: Just went and checked my MFD - reads 14.1V at idle (and 14.3V directly at the battery) - weird - seem to remember it being out by more (i thought 1V) when I first checked ..
Anyway - hopefully that helps; definitely sounds like you have dramas with your alternator if that's the voltage whilst idling/driving...
  • Like 1
No lights or stereo being run, without the engine running voltage is 12.4....Same readings from battery give or take .1... Took it to mechanics said the alternator is running and charging ok :dry: but its down near 12 and should be up near 14
hope u didnt pay him for that advice.. better off taking it to an auto elec, alternator might be on its way out
there is a chance the alternator is ok but the wiring is the problem. check the voltage at the alternator (although i have a feeling that if the earth to the alternator is dicky then it will lower the voltage reading you get there too).
ok im an auto elec...battery volts should be 13.8 - 14.4 with the revs up so the alternator is wroking harder and charging, gauge is always going to get lower as remember there will be a drop is volts in the leads, test the battery with a multimeter and also at the alternator there will be a differents onces again in the cable....if a alternator/ battery is lower then 13.4 running id be getting the alternator rebuild dont go out and buy one cheaper to fix urs
what do u mean how does it cost, to pull one down, clean, sand blast, replace bearing, and any other parts to make it new is cheaper the buying one,
we charge $132 plus parts, take half a day or so to do,
132 for half day is cheap :whistling:
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
