when you have seen both motors apart, yes.
forced induction is not really that much differance in cost once you include a new intake manifold for the de,but having said that, there is a crapload more bits "off the shelf" for the de.
bearing diameters are all alot bigger.
heads flow just as well as ported de heads out of the box. and the crank is much better,less harmonics and the block is alot stronger. with the nismo oil pump im using they are reliable to 8500. so nismo says.
one thing that needs to made avialable is 3d printed rocker covers with a re-located oil filler cap, and replaceable spark plug tube seals. same for the de really.
im also suprised that the full on drag guys still use the de as a base. (billet engine block) when the design of the hr block is way better for main bearing support. and if made billet they would be nothing stronger.
  • 3 weeks later...
making some headway with the intake manifolds.
not much room to work with, between being to tall and wide and keeping the overall volume as tight as posible has been a challenge.
this version was way to big in volume. not planning on making 3000hp..post-19586-0-73439500-1451449157_thumb.jpg
this version was all i could come up with with the available space.
post-19586-0-30800500-1451449169_thumb.jpgpost-19586-0-71650300-1451449185_thumb.jpgpost-19586-0-12658900-1451449198_thumb.jpgpost-19586-0-23325600-1451449215_thumb.jpg
  • Like 1
finished the intake manifolds apart from the balance pipe. and supports also the water to air pipes (i haven't worked out where to put it yet.)
each maniflod with the intercooler is about 4L. about 1 liter larger than i hoped but what can you do...
the charge pipe from the turbos will be a short 2" 90 and a 2" to 3" 90 degree reducer.
the water pump for the heat exchanger is a jabsco cyclone 32gal/min.with 3/4" hose. il be using 1" hose. i chose that over a Johnson cm90 because it flows more at the same head and is more compact and cheaper :)
  • Like 3
How come you chose to run them straight off of your plenum instead of run the plenum size you wanted and have the heat exchanger seperate?
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
