some more progress.
secondary injectors will fit, took abit to get them sitting in the rite spot so they dont spray on to the runner and port walls and without putting the hole in the wrong spot to start with.
post-19586-0-94566200-1453540872_thumb.jpgpost-19586-0-17971500-1453540885_thumb.jpgpost-19586-0-26049500-1453540898_thumb.jpg
swaybar will need some modding
had some action in the backyard withe the next doors tree...
  • Like 1
no speed sensors. not really necessary. atmospheric conditions can change the boost given the same comp speed. i will be running a balance pipe on the back of the engine to average the boost to each bank.
just working out the heater/turbo plumbing atm. + water to air cooler plumbing+ our lease is up and have to move.........
secondary injectors all mounted.
It looks schmick, nice job. But why go to staged injection when you can run injectors up to 2000cc that will idle and run nicely down low as well?
If it's bling, I understand. But the work / complexity increase would make me shy away.
because i want it to pass an im240 if need be. my ecu can run it, and with proper injector placement i wont need as big. better economy and more consistent mixtures.
ive got a set of moran billet atomisers that will do the job, but i want it done well. fyi the "2000 ish cc" injectors on the market are gas injectors and fail on a regular basis. there not meant for liquid petrol. let alone e85. the rubber seals inside swell and change there dynamic flow rate.
yes some updates. having our lease up sucks. house hunting has taken a front seat over this.
also i am abandoning the water to air intercoolers in the manifolds. the volume is to big and will make it lazy. (i need razor sharp throttle response for the paddle shift that im running.
also bonnet clearance is an issue. i want to raise the engine a cm or 2 for ground clearance. stock sump will be marginal at best,,
ive got some old hypertune s2000 plenum shells i am modding to fit. (shortening and mirror imaging one for the r/h bank)
the water to air coolers will be mounted in the inner guards out of the way.
all but finished my 110L fuel tank. all in 316L so it wont corrode. twin walbro 400's staged and an internal gated surge tank/pot
post-19586-0-09213900-1457252365_thumb.jpgpost-19586-0-20692500-1457252375_thumb.jpgpost-19586-0-53988000-1457252389_thumb.jpg
  • Like 1
  • 2 months later...
  • 6 months later...
  • 1 month later...
getting close. just finding the time has been hard + the 90 odd wires for the engine wiring harness took some time to make.
got the air shift piston and linkage sorted so i can use the stick and have paddle shift.
shouldn't get hot with the "super fan"
  • Like 6
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
