Just to clarify, personally i'm excited by those HR engines which feature VVEL (From what I remember VQ37hr and newer), VVL is cool but no where near as exciting (or new :)).
Have been thinking about the valvetronic system today, so that only controls valve lift, not timing right? So there'd be more advantage to come by mixing the two systems? The lift will allow the extra fuel to enter the cylinder, but if the valve is also opened earlier more fuel can enter, is this correct?
Should stop hijacking a very interesting thread now (carry on sir with the best gt-r build i've seen in ages :D). Anyway yes, VVEL does everything VVT and VVL did except it can control lift all the way to zero. With a VVEL setup you don't need cold start or a throttle body :).
straight from wiki:
"Nissan VVEL was first introduced to the US market in late-2007 on the 2008 Infiniti G37 Coupe sporting the new "VVEL" VQ37VHR Nissan VQ Engine (VQ37VHR motor specs: 11.0:1 CR, 95.5mm bore, 86mm stroke, 7500rpm redline). VVEL variable valve timing is now also used in the smaller VQ25VHR engine seen in the Infiniti G25 and the VK50VE V8 engine from the Infiniti FX50.
A rocker arm and two types of links open the intake-valves by transferring the rotational movement of a drive shaft with an eccentric cam to the output cam. The movement of the output cam is varied by rotating the control shaft with a DC stepper motor and changing the fulcrums of the links. This makes the continuous adjustment of the amount of the valve's lift (e.g., the amount of intake opening), during the intake valve event in the four-stroke cycle, possible. C-VTC and VVEL together control the valve phases and its valve events, allowing free-control of the valve timing and lift. This results in more efficient airflow to the cylinder, significantly improved responsiveness, optimizing the balance between power and environmental performance."
  • 4 weeks later...
There's an entire 370z half cut here in Brisbane for $7500, surely it'd have all the things you'd need!
The ecu would be of the same era as the r35 wouldn't it? That'd mean a COB access port would probably work should you want to mess around with things :)
http://www.prestigemotorsport.com.au/modules/stock/index.php?StockID=5047
finally got my engine! its abit grubby from the iced roads... but 11k miles on it.
ive measured it up. front shafts: same
distance/width of front diff axles ~500mm : same
splines in diff/ bolt pattern of p/s driveshaft union: same
distance between both engine mounts 700mm (will just fit inbetween rails.)
for diff to sit in same spot the engine will have to sit 60mm forward... (have to dummy fit it to see exacly)
cosworth pistons and carillo pro sa rods turn up in about a week.
need to sort out a r34 getrag for it...
well the x member engine mountings are usless. i will have to make custom brackets directly off the chassis rails. wich should free up some room in regards to the diff and x member clearance.
from what i can see, the x members job now only will support the rack and lower arm mounts. these can be simplified alot since the engine will not be sitting on the x member.
ps. got for sale now my built rb26,stock low k late r32 rb26, another rb26 head complete, late rb30 bottom end,autronic smc with cdi and loom for rb26, apexi 280 11.5 cams, buckets supertech dual spring and ti retainer kit and a whole heap of other rb26 related stuffs..
gonna need some room to do this. and to top it off im moving house.... lol.
love it dave. don't worry i'll have a cheap getrag for you. or if you flog all your old gear buy a bloody hollinger!
shame the bloody engine's ally bits are all bloody coroded. fken yanks. it would look so pretty otherwise.
still it looks clean inside which is what counts. :)
gots some more presents in the mail :)
post-19586-0-20103600-1307435455_thumb.jpgpost-19586-0-97411200-1307435529_thumb.jpgpost-19586-0-75109300-1307435597_thumb.jpgpost-19586-0-58183300-1307435669_thumb.jpgpost-19586-0-90566700-1307435727_thumb.jpg
on another note.
front diff ratio is 3.3:1 FAIL
front passenger drive shaft inner cv cup FAIL
SO for now, it will be rwd. just need to get it in the car and all running. with my big turbo. (s400sx4 72mm) i wont have time to bugger around with gearbox adapters and custom flywheels ect etc for now. + the bank balance will not let me at this stage.
to make the 4wd work i need to frankenstien a infinty front drive shaft and a r34 getrag welded to a vq35hr auto bell housing. also purchase a suitable crownwheel and pinion for the f160A front diff. and the matching rear. not a major job but for the time being i will get it installed and wired up and have some fun. besides all this has to happen in my garage lol.
oh and try and find some 60mm throttle bodies that arnt fly by wire. unless a vipec can run a vq35hr with the electromagnetic exhaust evtc cam control.
bell housing would be the easy part, and cheap. Budget around 500-600 (cheaper if you have access to a large mill and do it yourself) for something mint.. much like the hollinger to gtr housings, ive done a few custom ones like evo 6 to rwd etc and generally they cost me 200-300 trade.. and rated to same horsepower as the std cast items.
EDIT: Seen your latest post so ignore my post, i see you have the engine and gear already sorted. :P
impossible to put the GTR sump on. very different engine shapes from V6 to I6. far easier to do his solution and fiddle with the shafts and just change to a suitable ratio.
nice bits mate, can't go wrong with a set of carrilo rods and what look like cosworth pistons? I'm glad you are better with spanners than you are with a camera cause your pics suck!
this thing is still going to be mental with big V6 and a nice turbo. :)
how about using the stagea complete subframe? ive fitted the R32 one to a silvia but ive never seen the later VQ subframe... too wide possibly?
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
