Cool thing is that cops think all skylines are NA, they dont know that they come with turbos as well. So they'll just assume its NA and never pull you over to check. WIN!
I can say for sure that this DOES WORK and I can't believe someone else has thought of this too. Don't worry about the haters, they haven't fully understood the pure genius of this plan. I mean, how could it not work?
Since you and I are so alike, and obviously smarter than the general person on the street, I will also let you in on another secret. Not only can you get away with stuff by REMOVING sticker but sometimes you can also get away with stuff by ADDING stickers. You may have seen examples of this when people add stickers like Greddy, Garrett or Apexi to the side of their car thereby adding valuable kilowatts. Also you can give your car 4WD and an extra turbo simply by adding a GTR badge to the rear of your GTST (trust me, it works and that why all the GTR guys hate it cause they know they spent all that extra money for nothing. Hell...I'd be pissed to, hahahaa...lol, ROFL, LMAO).
Anyway...what I'm saying is I put stickers like "I'm NOT A DRUG DEALER" on the back of my GTST and I've never been pulled over by cops to search for drugs. I've also found "I NEVER SPEED" to work really well cause I know a guy who's mate tells me he was talking to a guy at a party who used to live with this guy who read on the internet that some guys had a friend who's mate's dad once read a story about a segment on Today Tonight that the new's readers brother got his hair cut by the ex-girlfriend who actually did this!
Anyway, it works cause cops are as stupid as you. Of course they are, I mean how could they be smarter, it's just not possible. But be careful you actually buy a turbo version first cause it might just be a non-turbo with the sticker put on. I have no idea how to check if it really is a turbo. Maybe someone on here knows ?
Edited by simpletool
  • Like 1
<snip>
The lulz are strong in this one.
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&search_in=forums
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM me and we can discuss it further.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
