Hi all, so the time has come for me to get new coils for my 20 as i still have the original ones >_<.
Was browsing through the fab section and saw a post on ls1 coils on a rb20, nothing was really discussed in detail so did a search and found some scattered info of people doing this and saying nothing but good things about them.
My question is who on here has done this on there rb? Was it an easy install?
I would really appreciate any info on this as I'm considering going this route as a full set (8) ls1 coils is roughly half the price of splitfires.
One massive pro to this setup is you can can your standard ignitor as the coils have them inbuilt, which seems really good as i'm sure the standard 20 odd year old ignitor would be the weakest link after upgrading to say some new splitfires.
Also having them mounted of the engine has to be better for a coil, not having all the heat go straight into the coil.
But can a standard ecu run them? They apparently can but there is stuff all info out there.
Cheers.
https://www.sau.com.au/forums/topic/355885-ls1-coils-on-a-rb/
The ignitor is just a high speed switch only in this case they are built into the coil assembly .
Some will say that returning to high tension leads is a backwards step in this day and age .
I reckon by the time you muck around with brackets leads wiring etc you may not have a lot to gain and it creates a bit of an eyesore .
Can you source good second hand std coils or explore ones off other RB twin cam engines ?
A .
I know OT but so much more to be gained from a 25 if you can manage it .
Why not go 26 ones as they are a bit newer? Or just get some yellow jackets or splitfires?
Avoid the red ones (won't put brand in for obvious reason) however they didn't last 24hrs
IMO yellow jackets are bang for buck and 200+ cheaper than splitfires and gave better results on my car
I use them along with 8/10 other rb fans I know.
They nurder the splitfire for reliability and throw a much fatter spark.
The better coil to use is the ls2 chevy truck coil. It will start bushfires in the next state. Can pick them up quite cheap off ebay too.
I read the diy but will the rb20 wiring be the same?
Basically I would go with the yellow jackets but how long have they been around for? No point buying a product that has a 2 year warranty when the company might not be around in a year or so. Not to mention theres stuff all info on where there made.
I'm going to see how much i can get ls2 coils for and go from there, no point if the setup is the same or more the splitfires. It looks promising though as the ls2 coils are meant to have a big spark.
Getting the car tuned and some other issues sorted and tuner told me that two of my coils are leaking to ground. Options:
1. repalce OEM ones with OEM ($$$)
2. aftermarket (not as much $$$ as above)
3. LS1 coils (that I ended up getting for free)
I think I will go with option 3... anyone got some decent photos of how they mounted them? Or what leads they used?
How did you find that out? Back to back, same tune, same plugs etc test on a dyno?
Bugger paying $200 each, the best of the 3 types (the LS2 Truck Coil-with the heat sink on the top) is only $24.75 each with $60 postage for all 6. So ~$209 all together. And these put out 120mA as opposed to 40mA for the base LS2 type. What do the factory coils put out?
http://cgi.ebay.com/ebaymotors/IGNITION-COIL-CADILLAC-GM-HUMMER-ISUZU-VEHICLES-UF262-_W0QQcmdZViewItemQQhashZitem5d2d7a3fedQQitemZ400194945005QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Edited by D_Stirls
Well I know why Nissan went straight coil on plug, there is f**k all room to mount the LS1 coils especially trying to have them neat and with equal length leads. Having a mate come round tomorrow to give me a hand.
I think I have had my RB20 yellow jackets for around 2 years now... They are still holding more power/boost without any issues than I would imagine you will ever need with a RB20
Well I got a dummy bracket made up which should do the trick; now I need to sort out the wiring. Will get a photo up of them mounted this weekend, if it looks as neat as I hope I might even do a kit.
By the way does anyone know if you still use the OEM "noise suppressor condensor" on the power feed to the LS1 coils?
Edited by bigmikespec
So the ones listed on ebay in the us there not a genuine gm coil are they? Just figured if your gonna get them might as well get the real deal instead of a cheaper knockoff.
If they are genuine then f**k me there cheap, so much cheaper then any decent replacement coils, well worth the hassles of mounting and wiring.
Still cant decide on whether to run these of just get yellow jackets, kinda running out of time before my tune, so kinda need to make a decision asap >_<
One issus i have noticed is the dwell time on the coils, i'm guessing you'll need to adjust it via the ecu as it has to be set to around 5ms, not to sure what a standard rb coil's dwell time is?
Edited by eightsixboy
This is what I use when I want a good cheap COP coil
http://cgi.ebay.com.au/FORD-FALCON-BA-BF-NEW-COIL-ORIGINAL-XR6-TURBO-4-0L-/190507883608?pt=AU_Car_Parts_Accessories&hash=item2c5b279c58
They are just as strong as LS1 coils. Had no problems on a 2jz @30psi of boost with a 0.9mm gap.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
