mico Posted March 7, 2011 Share Posted March 7, 2011 yer i know but kyle is pretty sharp and has reasons for most things. im sure if u ask him he will tell u. Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703141 Share on other sites More sharing options...
R31Nismoid Posted March 7, 2011 Share Posted March 7, 2011 I'd still love to know how you are meant to screw a nut into a flat flange Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703160 Share on other sites More sharing options...
mico Posted March 7, 2011 Share Posted March 7, 2011 turbo to mani flange yeah ? bolt slides through the turb flange and then screws into the threaded mani flange. then u can screw the nut on the end of that does that not make sense ?? Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703182 Share on other sites More sharing options...
Shane_954 Posted March 7, 2011 Share Posted March 7, 2011 Kyle probably has all his flanges made before he builds the manifolds. Most manifolds that he does would have the studs screwed in the flanges, not like these which are in the housings. Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703272 Share on other sites More sharing options...
BoostdR Posted March 7, 2011 Author Share Posted March 7, 2011 (edited) I have drilled the manifold flanges out with a 8mm bit. Will see how they fit on the studs when I get home. Should be fine if the holes are in the correct position as 8mm is a close fit. Here is the list of fittings I ordered to do the Water lines. I already have M14x1.5 to -6AN adapters in the turbo housing so you would need 2 of those to. I got mine from MTQ turbo's here in Adelaide Edited March 7, 2011 by BoostdR Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703360 Share on other sites More sharing options...
bigmikespec Posted March 7, 2011 Share Posted March 7, 2011 turbo to mani flange yeah ? bolt slides through the turb flange and then screws into the threaded mani flange. then u can screw the nut on the end of that does that not make sense ?? Makes sense... But why you would do it doesn't, not necessary. Would rather shear a bolt with a nut than a bolt in a threaded hole in a manifold! Nasty! Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703371 Share on other sites More sharing options...
BoostdR Posted March 7, 2011 Author Share Posted March 7, 2011 So the 45's come out of each turbo(needed to clear the actuator rod) then both lines go into the Tee(one with a straight connector and the other with the 90) Then out the other side of the tee with a straight connect to line to another straight connecter to the barb adaptor and into the OEM 10mm ID pipe. I will re route the original hard pipe boost and vac line with some silicon. Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703386 Share on other sites More sharing options...
BoostdR Posted March 7, 2011 Author Share Posted March 7, 2011 (edited) Now that I have drilled out the manifolds I will be able to bolt up the turbo's and dummy fit up my hard pipes. I reallllly hope they go on without the need of modification. Will let you know....with more pics of course. My power steering resevoir will need to be moved however. Edited March 7, 2011 by BoostdR Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703397 Share on other sites More sharing options...
femno Posted March 7, 2011 Share Posted March 7, 2011 eh...no modifications are ever straight forward or 'bolt on'. i hope the results are worth the frigging around. keen to see how they go back 2 back - car seems like a weapon already Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5703553 Share on other sites More sharing options...
BoostdR Posted March 8, 2011 Author Share Posted March 8, 2011 I had to enlarge the flange holes to 9mm to fit correctly. The front Dump pipe O2 sensor also doesn't fit as it fowls on the manifold My hard pipe kit does fit, I am also using an Apexi Z32 adaptor pipe kit...but will have to check if the filters still fit in the engine bay Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5704934 Share on other sites More sharing options...
N1GTR Posted March 8, 2011 Share Posted March 8, 2011 Love the crinkle coat Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5704951 Share on other sites More sharing options...
Scooby Posted March 8, 2011 Share Posted March 8, 2011 is that a valve in the pcv line? Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5705005 Share on other sites More sharing options...
R31Nismoid Posted March 8, 2011 Share Posted March 8, 2011 You wouldn't really want the outlet pipes that close to the manifold tube anyway though ye? Total custom piping required to move it as far as possible unless you plan to run a sheet inbetween? Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5705053 Share on other sites More sharing options...
BoostdR Posted March 8, 2011 Author Share Posted March 8, 2011 is that a valve in the pcv line? its a tap Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5705290 Share on other sites More sharing options...
BoostdR Posted March 8, 2011 Author Share Posted March 8, 2011 (edited) You wouldn't really want the outlet pipes that close to the manifold tube anyway though ye? Total custom piping required to move it as far as possible unless you plan to run a sheet inbetween? I will be running heat wrap on the manifolds and make up a deflector sheild with tags that are held on by the hose clamps in that area. Not interested in reinventing the wheel -->Cast alloy pipes are a pain to weld. I may be able to get some more clearance by rotating the rear turbo compressor housing. Pretty sure its already close to max clockwise rotation available however. Now I have to decide what to do with the pipes. Crinkle black with black silicon or as is with black silicon... Edited March 8, 2011 by BoostdR Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5705291 Share on other sites More sharing options...
BoostdR Posted March 8, 2011 Author Share Posted March 8, 2011 Just another thought....my bonnet clearance will be awefully close with the RB30's height considering the timing cover doesn't fit under...from what I can see it actually won't fit with the height of the top pipe. Will have to have a closer look at that. Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5705294 Share on other sites More sharing options...
Deano 1 Posted March 8, 2011 Share Posted March 8, 2011 Alot of messing about, I'm a thought 6boost would have trail fitted them before they started selling them. Owell hopfully you get the gains your after, they sure would look nice ceramic coated. Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5705328 Share on other sites More sharing options...
gtr fan Posted March 8, 2011 Share Posted March 8, 2011 Are you sure you didn't just get a slightly different set? I was always under the impression that they just bolted up and away you go as I don't think we have heard of these type of issues from others who have use them. I have always thought of buying a used set if/when they come up for sale as they look like a great product. Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5705488 Share on other sites More sharing options...
limpus Posted March 9, 2011 Share Posted March 9, 2011 This might be pure hearsay but i remember reading somewhere that heat wrapping 6boost manifolds voids the warranty with them...is this correct...came to mind after reading BoostdR's comments... Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5705604 Share on other sites More sharing options...
BoostdR Posted March 9, 2011 Author Share Posted March 9, 2011 Kyle pointed out I would have most of these issues as it was the only way to make a decent collector. The idea of this thread is to identify a step by step installation guide and to outline the outlay versus performance gain. They will be heat wrapped never the less. There close proximity to the rocker cover and hard pipe we induce too much radiant heat even ceramic coated. Matt Matt Link to comment https://www.sau.com.au/forums/topic/355887-6boost-rb26dettt-manifold-install/page/2/#findComment-5706411 Share on other sites More sharing options...
