6boost are monitoring this thread. I didn't buy them direct.
I was certainly monitoring the tune, had my wideband O2 hanging out the side pipe. I kept the boost down as I had no head room left. Plenty left in her with more fuel. I'm half expecting my damaged to be oil surge related to be honest.
  • Replies 161
Flow tested the factory manifolds against the chinese stainless and they flowed 50% less, 6hrs of porting the OEM and got them within 15% of the stainless.
Interesting info, any idea where the 6boost manifolds stack up?
Hmm bugger...
So what was the end result with the manifolds? in terms of power/response gains-losses.
I didn't get it on the dyno. However:
1bar was made at the same point, but may improve if it was retuned
my 1000cc injectors maxed out at .35bar less boost so the car makes more power no question
No losses anywhere.
Idle is less stable however....
Matt
Yeah shithouse ay.
Are you going to make any significant changes to the engine power wise or are you just upgrading the oiling side?
Still keen to see dyno results back to back...but theres no denying seat of the pants feeling, except for placebo effects :)
Yeah shithouse ay.
It will certainly be on the dyno when it's back together. I don't think I need any more power...can't imagine what it will go like on 1.8bar. May fit the bigger plenum I have here while its out.
Matt
No losses anywhere.
Matt
Is it a MAF based ECU?
thats no good about the engine! from past experiance no3 or 4 spinning and the rest of the bearings ok tells me oil debis. as they are the first to get oil. and the first to get any contaminants aswell. where as if its no 1 or 6 then id look at oil starvation as a posible cause as they are the last to get oil.
unless a grub screw fell out or something..
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
