hey guys, trying to sell my complete car not running. however, if i dont get the price im after im willing to strip it as long as i have buyers for ALL the below items :)
Apexi Power Fc + Hand Controller for r33 rb25det - $1200
GCG gt34r Custom Garret Turbo kit with 1 bar actuator (slightly bigger then a highflow and cost $2700 with dump pipe brand new) - $1200
r34 550cc Deutchwerks injectors - $400
BuddyClub Coilovers Race Spec - $1000
r34 rb25det Gearbox with heavy duty clutch EXCELLENT CONDITION - $1300 or 1600 as a full manual conversion
IF i have buyers for ALL these, i will then also have the following for sale
r32 gtr seats, good condition with no tears - $450
HKS EVC 3 boost controller complete - $220
Blitz return flow FMIC (slightt damage but does NOT LEAK) - $200
Blitz DD bov with hot pipe - $120
Walbrow fuel pump - $120
z32 afm with plus - $170
Apexi Pod Filter - $50
r33 Series 2 front end (includes IMMACULATE headlights, bonnet, front bar, with foglight/indicators and reo) - $800
Apexi pen turbo timer - $100
Items located in Sydney, can post at buyer expense. However, as stated earlier, i must have a buyer for the first 5 items before i think of stripping a complete car. you can contact me on 0403 558 930.
Cheers
Zack
https://www.sau.com.au/forums/topic/355895-r33r34-rb25det-performance-parts/
Id be interested in the HD Clutch if someone does want the Gear Box
Ill probably need a spare gearbox as mine has issues from Dyno time... $1000 for the box and sell the clutch to pmd89 for $300 :cheers:
all PMs replied. alot of interest guys. but once i have a sale on the first lot of items ill begin stripping. :)
and no, i wont sell the gearbox for a $1000. I AM NOT IN NEED OF MONEY. so the prices are fairly firm. im just tired of seeing it sit in my backyard for over a year :)
GEARBOX IS 1300 with or without clutch :)
mate if you read my post. You would notice im focusing on organising buyers for the Power Fc, Injectors, Turbo kit, gearbox, and coilovers first before i part out the rest of the car.
I have Pmed pix to those who have requested any of those parts. but i will take a pic of the evc3 for u tomorrow :)
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
