Hey all.
Just wondering,
Which would perform better?.. ?
Buying an R32 Gtr and I would just like to know what I'm dealing with..
This is for a daily driver with some balls when I tell the ECU to have some, but also be nice on fuel with decent response,
And.. a casual track(drift mainly) car (when I make it to the track).
I'm not really interested in drag racing.
I'm considering twin GT2860s in replacement of the stock ceramics which as far as I know are GT25s?..
Any advice would be great.
Thanks.
Also, it seems I posted this in "for sale".. My bad. sorry.
https://www.sau.com.au/forums/topic/356011-rb3026head-or-a-rb28-stroker/
I should have pasted the Nismoid quote in the other thread....
You gotta search bro! At the top of this section you'll find dyno result threads, there's one for RB26 results which should have some RB28's in there, and there's also an RB30 hybrid thread. READ THEM AND SEE WHAT PEOPLE HAVE.
That being said, RB30.
Save your money and buy an R32 GTST and RB25 or 30DET that .
If you can live with a four banger buy a Silvia .
No offense but a GTR is a poor choice for a drifter and far cheaper cars would do the job a lot better IMO .
GTRS are heavy cars and throwing more money/cubes/power at them doesn't fix this .
A .
argh, just deleted my post.
Once you factor in the extras for the rb30 conversion (adapter plates, oil pickups, exhaust fabrication, modding alloy sump to bellhousing, etc etc) the cost of the 3.0 vs the 2.8 is line ball. No practical difference.
The 3.0 is a major head-fsk to get it all in cleanly and neatly and working. Unless you really like DIY welding/grinding etc, consider giving it a miss. In hindsight I would do the 2.8 (even though the 3.0 build yeilded a pretty good result).
Engine characteristics - the 3.0 gives you 2000cc extra but unless you get a different crank, limits your rpm. You will have to adjust driving style (eg grabbing 3rd before 100kph).
The 2.8 stroker kits can come with billet crank or full counterweight or both and often rated to higher rpm operation than the 2.6.
There's a lot of unexpected hassle with the 3.0 build that you can avoid with the 2.8.
Engine characteristics - the 3.0 gives you 200cc extra but unless you get a different crank, limits your rpm. You will have to adjust driving style (eg grabbing 3rd before 100kph).
balance the 30 crank and put a decent balancer on it and lots of people spin them to 9000. its a myth that when built they cant rev.
Ok so what rpm in your opinion is ok for them?
Like having too much low down grunt you have to be a little more careful with the throttle?
I think im in a decent position to comment on this topic. 2.8 stroker, GT block, GT RS's, E85. To sum it up I want to put my mega dollar engine in the trash after driving N1GTR and MarkoR1's car. Sorry , but the 2.8's just do not compare.
^^ This
^^ and this.
/thread
Oh, the other reason I want the gtr is because the car I'm driving now, spins too easily in the wet, it'd be nice to set the torque to the front n rear once it rains..
I've heard from many people that the rb30/26s are awesome..
So the rb30s have a wider powerband?
thats all to do with you right foot though... im sure a fully built gtr would spin the wheels in the wet if given the chance. if you want to drift it an r32 gtst would be your best bet for a skyline in my opinion, once again what is your power goal you dont need 400rwkw to drift, although it would make it more fun rolleyes.gif
Budget?
You'd need a torque split controller to do that and to be honest, your right foot is much better tool when it comes to throttle control than anything else.
Why not have a dedicated drifter, and a GTR daily? that way you get the best of both worlds rather than a hugely compromised GTR that you have to sod around with to try and drift.
+1
I'd much rather build a mild GTST to drift in than a GTR. save you a few hundred kg's and stuffing around with the drivetrain too much.
Most of the difference will be in the ability behind the wheel
You can't "set" GTR's to a set % front and rear. They are not like evo's or a wrx.
Yep, but with a little mucking about either with a Torque Split controller or mucking around with the accellerometers or whatever they are (the lat and long ones) you can have a bit more of a play.
I can't have 3 cars parked out the front of my house, and ...I dont have that much money...
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
    • Interested to see any videos of this or on the dyno. Mine currently has HKS secondary cats i am undecided if I want to remove them. What did it set you back to get the tube done? And what mods have you got to get that power? I was looking at a racebox flash tune but maybe a proper tune would be better if these guys are good.
