Heyaz
Im selling my female flinders range scorpion and also my yellow legged centipede . The scorpion is about 10cm long from tip to tip ad still has some growing to do she eats very well on crickets and has no worries about letting you watch her chew a head off she's a yellowish green color mixed with brown.the yellow legged centipede would be around the same length maybe abit longer like the scorpion still has some growing to do, for anyone that hasent seen these things hunt or feed they are vicious to say the least he is lightning fast and has front legs which over thousands if years have evolved into fangs they are massive. Both come with their own glass tank house which are matching size with a cave for the scorpion and a vine plant for the centipede. Please note BOTH ARE VENOMOUS and both WON'T BACK DOWN TO YOU especially the centipede although scorpions are pretty calm once you have them out . Pics can be sent via email although mms would be way easier (and free) pick up is from eaglevale or maybe could arrange to meet up somewhere . They are the best topic point for visitors when in display and watching them hunt and eat is mad (beats deadly predators on discovery channel) I'm hoping for $130 for everything which is cheap when u add everything up
Scorpion $70
Centipede $70
X2 matching glass tanks $60
And also a scorpion facts book
If you have any questions my number is 0431718181 or can message me here :-)
https://www.sau.com.au/forums/topic/356057-nswfs-pet-scorpion-centipede/
  • 4 weeks later...
I'm in eaglevale matey 5mins off ctown m5 exit and they eat crickets I feed them once daily but you can feed them once weekly, crickets you buy a box $5 or u could breed your own which is basic they also eat woodies , flies , bugs basically anything that moves is fair game ;)
hey mate im frm st leonards area...intrested in ur pets and i had scorpions b4....does ur tank come with heat mats or such for winter? and also would u meet half way or part way?
Hi mate I'm happy to meet up somewhere and no they don't come with heat mats iv had them going on a year now and have never had any issues with heating
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
