Hey guys,
just after some help in regards to upgrading the sound system and before i get my arse handed to me lol im not asking for opinions on brands etc
Need to know if slim line speakers are necessary for both front and rear speakers? Also im not looking to put amps, subs as im just after some clean sound with bass (not car trembling kind just nice deep kick).
My shopping list so far consists of: (1)Double Din Bracket & A/C unit
(2)Either Pioneer DEH-8350SD (Single Din Unit)+Pocket or Pioneer AVH-P3300BT (Double Din DVD Unit)
(3)Fronts depends on mounting space
(4)Rears? I read its 6x9 but it looks more like 6"...i want most of the bass from these obviously. Also depends on mounting space.
Appreciate the help guys :)
Edited by TUFF_350
https://www.sau.com.au/forums/topic/356061-upgrading-sound-system/
Cheapest place for item 1 is USA, from memory from Nissan Japan was $650 for the parts, JB (went for quote only had no intention) $750 and from the USA (via ebay) $411. You don't need the bracket, just the trim piece and the AC controls.
Yea this is what im getting from ebay: http://cgi.ebay.com/ebaymotors/NEW-JDM-05-07-Infiniti-G35-coupe-sedan-double-din-kit-_W0QQcmdZViewItemQQhashZitem4cf21163f3QQitemZ330478740467QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Around $350 delivered which is hot :D
Ah you be lucky and have the later dash!
Haha thanks bro.
Can anyone confirm this is true: Front speakers are 6.5" with 2.8" depth, Rears are 6X9" with 3.5" depth?
Got this from one of the speaker sites where it actually lets you specify your car for fitment.
Thanks.
Have you browsed the G35driver forums? I believe they have a stereo section there. If not someone like Chris Rogers would know.
Seems as the premium BOSE system (which i dont have) has 3 sets of speakers,
mine only has fronts and mids in the pillars. Job for Chris i think lol!
Haha thanks bro.
Thanks.
not exactly sure on the size of the speaker as i no longer have the box, but they are hertz mlk 165 (left) alongside the standard speaker(right). They fit in the factory location with a mdf spacer.
I have a Hybrid Audio front stage which has the L6 midbass driver in the stock door location mounted to an MDF baffle
The speaker size is 181mm (7.1") overall diameter with a 77mm mounting depth.
As for the rear, the only thing I have back there are the subs :)
Ok guys im bout ready to get everything shipped,
but have one final question. Should i be looking at an amp to power the speakers? Ive been googling the shit outta this and im getting mixed opinions, some say yes cos obviously you wont be using the speakers to their potential. Others say yes cos you'll ruin the speakers by underpowering them and others say no they are fine to run off headunit...
Headunit is Pioneer AVH-P3300BT and speakers are Massive Audio VK6 Component (front) and Massive Audio VX6 Co-Axial (back).
Thanks guys ;)
My 2c.
Head unit is a good start and will have plenty of support if purchased locally.
Speakers I would demo, may be marginally better that the factory units or they could be gr8, but you can't tell on-line.
Demo some gear and decide what you like, you don't have to get everything at once. Build your system slowly if your budget won't stretch.
I suggest if your close to them, get yourself down to Call Frankston Car Audio and have a chat with Mark the prop. He is offering insane deals on quality gear right now.
http://www.frankstoncaraudio.com.au/attachments/File/OzblissClearancePoster.jpg
Crescendo Opus :thumbsup:
Edited by mosoto
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
