Hey guys,
just after some help in regards to upgrading the sound system and before i get my arse handed to me lol im not asking for opinions on brands etc
Need to know if slim line speakers are necessary for both front and rear speakers? Also im not looking to put amps, subs as im just after some clean sound with bass (not car trembling kind just nice deep kick).
My shopping list so far consists of: (1)Double Din Bracket & A/C unit
(2)Either Pioneer DEH-8350SD (Single Din Unit)+Pocket or Pioneer AVH-P3300BT (Double Din DVD Unit)
(3)Fronts depends on mounting space
(4)Rears? I read its 6x9 but it looks more like 6"...i want most of the bass from these obviously. Also depends on mounting space.
Appreciate the help guys :)
Edited by TUFF_350
https://www.sau.com.au/forums/topic/356061-upgrading-sound-system/
Cheapest place for item 1 is USA, from memory from Nissan Japan was $650 for the parts, JB (went for quote only had no intention) $750 and from the USA (via ebay) $411. You don't need the bracket, just the trim piece and the AC controls.
Yea this is what im getting from ebay: http://cgi.ebay.com/ebaymotors/NEW-JDM-05-07-Infiniti-G35-coupe-sedan-double-din-kit-_W0QQcmdZViewItemQQhashZitem4cf21163f3QQitemZ330478740467QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Around $350 delivered which is hot :D
Ah you be lucky and have the later dash!
Haha thanks bro.
Can anyone confirm this is true: Front speakers are 6.5" with 2.8" depth, Rears are 6X9" with 3.5" depth?
Got this from one of the speaker sites where it actually lets you specify your car for fitment.
Thanks.
Have you browsed the G35driver forums? I believe they have a stereo section there. If not someone like Chris Rogers would know.
Seems as the premium BOSE system (which i dont have) has 3 sets of speakers,
mine only has fronts and mids in the pillars. Job for Chris i think lol!
Haha thanks bro.
Thanks.
not exactly sure on the size of the speaker as i no longer have the box, but they are hertz mlk 165 (left) alongside the standard speaker(right). They fit in the factory location with a mdf spacer.
I have a Hybrid Audio front stage which has the L6 midbass driver in the stock door location mounted to an MDF baffle
The speaker size is 181mm (7.1") overall diameter with a 77mm mounting depth.
As for the rear, the only thing I have back there are the subs :)
Ok guys im bout ready to get everything shipped,
but have one final question. Should i be looking at an amp to power the speakers? Ive been googling the shit outta this and im getting mixed opinions, some say yes cos obviously you wont be using the speakers to their potential. Others say yes cos you'll ruin the speakers by underpowering them and others say no they are fine to run off headunit...
Headunit is Pioneer AVH-P3300BT and speakers are Massive Audio VK6 Component (front) and Massive Audio VX6 Co-Axial (back).
Thanks guys ;)
My 2c.
Head unit is a good start and will have plenty of support if purchased locally.
Speakers I would demo, may be marginally better that the factory units or they could be gr8, but you can't tell on-line.
Demo some gear and decide what you like, you don't have to get everything at once. Build your system slowly if your budget won't stretch.
I suggest if your close to them, get yourself down to Call Frankston Car Audio and have a chat with Mark the prop. He is offering insane deals on quality gear right now.
http://www.frankstoncaraudio.com.au/attachments/File/OzblissClearancePoster.jpg
Crescendo Opus :thumbsup:
Edited by mosoto
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
