Top Mount Manifold For Rb25Det, Stock Injectors, Hdi Boost Controller
Hey all,
Got the following for sale
1) High mount JJR manifold for RB25DET, has wastegate port for 35/38mm gates. Brand new $200 ono. Never fitted it on my car, bought it about a year ago.
2) Stock Rb25det injectors, 6 of them purple tops. Suit highflow maybe or someone returning to stock $60 ono
3) A HDI EBC. Fits into the coin pocket above the gear stick. $200? ono
But I have a proposal to all Sydney people and people willing to post. I need a 3" bellmouth dump pipe to suit an R33 GTST with the Nissan turbo flange and standard cat. Must be a direct fit for a standard car. No cracks. Preferably something made of stainless steel. I don't want your stock pipe.
PM me guys.
If photos are needed, just ask. The JJR manifold can be found on their website(its the only JJR manifold for Rb25 on their site).
Located near Parramatta Sydney.
I need the dump pipe before next week friday. I will trade my current dump pipe which is a split dump with atmo screamer pipe for a 3" bellmouth with cash either was as necessary.
  • 2 months later...
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
