Im installing some bosch 840cc with billet fuel rail and also a sard fuel reg, I'll be running braided lines and AN fittings all the way through...
Can I replace the std ryco fuel filter with a billet fuel filter?
http://www.vpw.com.au/productgroup.asp?CatID=6&SubCatID=771&priorCatID=771&PrdGrpID=4887
Are these just a pre-filter?
Is there a difference between an in-line filter and a pre-filter?
Would 30 micron be ok by itself or would I need to use a 100micron and then another with a 30micron filter in it?
I dont have a surge tank yet, just an intank bosch pump.
these are a reusable filter which you can take apart and clean which I thought would be good since E85 is gonna clean out the fuel system and possibly clog up the fuel filter when you start using it, plus they AN fittigns meaning they are nicer to install and easier to remove than pulling tight rubber hose off a barbed end...
Anyone with experience with these?
so vpw has recommended this:
http://www.vpw.com.au/productgroup.asp?CatID=0&PrdGrpID=4344
they didnt give a reason why I needed this huge one but they were aware of my setup...
it supports 2400hp wtf....
I ran the small proflow one and had the o-ring blow out while driving, they blamed the e85 straight away, even though it had gone in earlier that day and I had only driven for 1/2 an hour, it turned out the orings are too big so they cant be tightened right up...
I would go for the other style, stainless mesh is much better than sintered bronze imo.
Hmm interesting.
They cost quite a bit, but I suppose in the long run it wouldn't be to bad just replacing the inside filter.
How big are those damn things? In the photo they make it look as big as a damn muffler!
well its a washable filter being stainless steel mesh and all...
That was my next question?
I could order one in and its the size of a muffler or the size of a texta, there are no physical sizes mentioned...
I wonder if it would fit the std bracket, that would be nice...
there are also these ones...
http://www.racepartsolutions.com/proddetail.asp?prod=MAG%2DFilter
We recommend 74micron for inlet, 25micron for outlet before the carburetor/regulators
Damnit so that is pretty big. Definetely not engine bay fitment size.
Let me know what you end up deciding on because i'll get the same.
You have no idea how much swearing goes on in the garage every time I try and take off the braided lines on a Ryco barb fitting.
They those braided lines with the little splinters of steel sticking out of them, giving you a modern simulation of what it's like to escape from Auschwitz?
Why not use a ryco z373 falcon efi fuel filter? http://www.rycofilters.com.au/catalogue/product/make/FORD/model/FALCON/part/Z373
or even a volvo z400? http://www.rycofilters.com.au/catalogue/product/part/z400
both have screw in ends, tho the z373 has m14 thread both ends. They are a cheap replacement and readily available
  • 11 months later...
Right, just bumping this thread rather than posting a new one.
I'm in the process of collecting parts to upgrade my fuel system again, so far I've purchased a HKS fuel rail and Sard FPR, will be buying some ID1000's in the next few days as well. The plan is to run AN -6 braided hose for the supply and return fuel lines in a standard single entry setup for now. Now I just wanted to find out if it would be beneficial to run one of these inline filters in addition to the standard fuel filter? Say something like this:
http://www.frozenboost.com/product_info.php?cPath=219&products_id=268&osCsid=ccd36ac1115ad3561f7fcba7f6945c63
Or would it simply be a waste of money given the extra fittings etc. involved? The idea is to start getting my system E85 compatible but will still be using pump 98 until E85 is more readily available over here. At the moment I sort of feel like the extra filter probably isn't needed but thought I should ask before I order fittings. I'm also a little skeptical of the quality of things on the website I linked, so is there a better option if these are a worthwhile thing?
I had one of the proflow filters leak with that style, came down to the oring in the end. I upgraded to the small cigar shaped ones like 75Coupe showed above with no issues since. I wouldn't trust the paper stock filter with ethanol for prolonged use.
Yes I won't keep the stock fuel filter when I make the switch to E85. Would I be better off replacing the stock one now with one of these inline filters but with barbed fittings instead of the AN fittings? To save having to replace the hose from fuel pump to rail?
interested to hear how you get on with this Hanaldo...
Id also be interested where you get your parts from and your calculations of length of hose and fitting types?
I could never estimate the fitting angles that were needed for a clean tidy install... so I went and did other things, like collect CF...
Ive still got the rails, reg and large injectors waiting for my e85 upgrade sitting waiting for time and the braided lines...
I felt like I was coping out if I used normal high pressure fuel hose and barb fittings when I had AN fittings and braided lines on ther parts of the fuel system...lol.
this is what made me stop....
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
