  • Replies 104
27th September 2011
Car was towed to the workshop yesterday, no real progress was done, just cleaning and finishing up things that needed doing.
Called into HPIAB on my way to work today, so I could drop off some parts for the build and this is how the engine looked.
Called in on my way back also, to see how the day went, and this is what I saw...
Ahhhh, that's where it went.
Morrie had been a busy little bee today, pulled the old engine out, swapped parts from the old to the new, and even cleaned the engine bay out.
Sump is going on tonight, and should the engine should be going in the car tomorrow...not too much longer now biggrin.gif
28th September 2011
Engine is in the car, all wired up, and looking schmick. Could turn the key...but its missing oil and fuel....and still waiting on the exhaust manifold from the ceramic coaters. Once the manifold is back, on goes the turbo, and all the inter-cooler piping, etc. Then onto turning the key and the run-in process and tune...hopefully next week, it could be a anniversary of when the original engine blew up.
should be a pretty fun 300 od kw once its all done. not going e85 while your at it?
Maybe later. I feel that E85 is not suitable for running the engine in, plus I have a trip over to Victoria at the end of October for SAU Nationals, so I don't want to be dependant on E85, would like the flexibility and mileage of 98.
completely agree, also contemplated doing the trip on e85. the 400L i allowed for wouldnt be ideal
Friday 14th October 2011
Finally after 1 year and 7 Days the R33 lives again. Called into HPIAB at around 9pm on my way home from going out to tea and Morrie says "Good thing your here, my tune hasn't shown, so I am going to run your Car in"...My reaction was along the lines of BigCheesyGrin.gif
Car was put on the dyno, and run in. Lots of smoke as the residue oil was burning off from the previous engine failure, but after awhile it disappeared :)
The new engine ran like clockwork with nothing breaking or leaking. During the run in process the Turbo and Exhaust manifold hot a nice red hot glow to it :), I'll try and get a pic.
Saturday 15th October
Apparently the car was run in some more, and the timing touched up from the previous tune to coincide with the new camshafts. I don't know exact details as I was at work all day.
I had the pleasure of watching the motor being run in with the car on a chassis dyno. This motor is going to be very strong..
Here's a cool pic, a bit of heat being generated i'd say. my iPhone captured the image in infared for some reason..
Good to hear mate. So ready for a tune??
Not too sure, I know on Saturday it was having a secondary run in, and the timing was being touched up, I have heard it is going back on the rollers today (Sunday 16th), so I can't exactly say for sure.
Cheers Matt, sorry for the car's smoke trying to kill you :P
Sunday 16th October
Went to the workshop tonight to watch the final instalment of the Engine run in...was rather boring actually. After that was done we dumped the run in oil, and replaced it with some nice new fresh stuff...and then we decided to do some fun stuff...Power Runs.
Back in 2009 the boost tee was set to 14.5-15psi, and that was what it was still set too. Lets just say this was a semi bad idea, why was it bad? The amount of power that was being made was too much for the clutch to take so it slipped...or just wheel spin.
So we disconnected the boost tee and ran actuator pressure...which was just a measly 8psi. Ran the car up, no issues at all there...the power figure is about 220rwkw at 8psi with about 400nm of torque and a lot more response all over.
This thing is going to be a monster once I have a new clutch and tune in it :w00t: ...which is going to be a LONG way off :(
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 馃槄. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 馃槀.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven鈥檛 played with her in a while, but I鈥檓 back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 馃
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
