Wheel Offset For R33 Gtst
Hi Guys,
i know there is a lot of questions regarding offsets and wheel sizes for skylines, but i'm a newbie and haven't found any r33 gtst with the dimensions below
18x8" offset +40 front
18x9" offset +40 rear
my car is lowered 30mm with king springs, will they fit and will i have to do anything to the guards??
  • Like 1
....It will look fine
But If you wanna be one of these guys that spend a fortune to get the flush look, even though it provides no great performance benefits,then go for it.
EDIT..i do hope your not running standard shocks with those springs..If not you should spend your money on some good quality shocks before worrying about different wheel offsets.
need wider dude....
+40 will look like a bag of dicks
how do you know what a bag of dicks looks like??
Arent you meant o be on some cruise anyway.. :P
It may not look the greatest but it will still look better than most and i think a good quality set of shocks should be of higher priority if they are not done already..Crappy shocks with hard springs and no tyre sidewall = a pretty crappy and unsafe ride
Why put all this pressure on these kids to make their car look a certain way then grumble when they get pulled over and defected because they spend more money trying to look cool rather than actually enhancing their vehicles performance.
EDIT anyway if your that concerned just stick some spacers on them..
What fortune is needed to get the flush look?
Every set of rims i see with a decent amount offset is up around $1500+
You can get a brand new set of 18/19x10.5+0/12/22 TE37/CE28 reps from USA for less than 1.4k.
Fair enough,Im a poor kent so Im happy with my s/h enkeis for 500$ :laugh:
+38 offset, how much wheels spacer would get them sitting flush? 20mm 25mm..Or would it still look like a bag of dicks?
i know there is no real standard as everyone like different looks and stuff but thats nice i think.... lol no spacers
and only $850 a few weeks ago on here with tyres..
but as Arthur T3 said just stick spacers in your ones...
Thanks for the feedback guys.. I have replaced the king springs with Tein coilovers just today and the wheel dimensions I put on earlier were for a set of bbs lm replicas.. Does any1 know where I can get a set of lm replicas that will sit more flush?
VarrsToen in the US make BBS LM reps, but they will sit more poke than flush without rolling/flaring/pumping (19x9.5/10.5+0)
18x9+32 all round. Ran fine without modifying the guards. Only time I got scrapage was on bumpy corners...but a guard roll fixed that, and it's completely related to how low/high your car is. But yeah, as Hamish said...you'll be unhappy with the looks after a while, if you don't get offset and width right straight up. Mine look okay, but I'm now trading my rears for 9.5...will make things look even better without the need for guard flaring.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
