so i have an rb20, fully stock, side mount intercooler etc. now when i rev it up and drop the clutch or go to do a hillstart, it nearly dies, then slowely revs back up. i checked for a leak in my piping or bov, couldnt seem to find one? i checked my bov and nothing. thought maybe the spring might be too loose but i dont know? makes an awfully big spooling/sucking noise at even quarter throttle. so i dont know why this could be?
i also have a problem with it missfiring on boost between 3 1/2-5 grand, then pulls fine. i bought new plugs. NGK BCPR6ES. gapped at .8mm. still did it. checked the cam timing, set it at 15 degrees. still does it. now im using an rb25 engine harness, which is a little stupid as now it idles at 1.5-2 grand! but 4th, and 6th injector are the wrong way around on the ecu. so swapped them around. still does it. i'd heard about hairline cracks in the coilpacks, so ill have to check them, but if anyone else knows of any other reasons which it may be doing this i'd love to know so i can try them.
cheers, Ben
https://www.sau.com.au/forums/topic/356125-rb20-problem/
Spooling noise could be an exhaust leak, anything from the exhaust manifold gasket to broken studs/nuts relating to the turbo.
As for the hillstart thing, could be a slipping clutch or intake related (dirty/bad AFM, intake manifold gasket leak etc)
As for mis-firing, could be the ignitor (if it's the series that doesn't have the ignitors built into each coil), though they usually work fine when cold, it's not until they're warm they start causing problems.
https://www.sau.com.au/forums/topic/356125-rb20-problem/#findComment-5699950
yeah ill have to check the exhaust manifold for leaks etc. as for hillstart thing, the car had a n/a in it before and the clutch was fine, the clutch in it is supposed to be able to handle turbo, and it drives fine when im rolling if i chuck it into first and give it some stick, only when taking off on a hill. ill have to check the coilpacks and ignitor. and afm and maybe clean out the t/b
https://www.sau.com.au/forums/topic/356125-rb20-problem/#findComment-5700296
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
