1993 Nissan 180sx $15,900
2.0 Litre TURBO (TURBO IS 30,000KMS OLD reconditioned)
106,000kms (but new cluster that says 13,000)
5 Speed man.
33GTR FMIC 600x300x65 w/ custom stainless steel piping
Custom Cold air intake and heat shield for pod filter
White with Blue Pearl
Vertex rear bar and side skirts, modified standard front bar
16x8” Volk Racing 3pce GTP rims 225r, 205f
JIC Fully adjustable coil overs
Cusco adjustable front & rear strut braces
Turbo back Fujitsubo 3.5” exhaust with hiflow cat
4 puck button ceramic sprung centre clutch, almost new(10000kms)
Cusco lightened flywheel, almost new (10000kms)
Aftermarket mechanical Locked diff (unknown brand) think its NISMO
Apexi S-AFC air/fuel computer
Bosch 040 Motorsport Fuel pump, up to 550hp capable
HKS mushroom Pod filter
NGK platinum spark plugs installed 10,000 kms ago
Greddy Profec B Electronic boost controller ‘hi’ set at 15psi low set to 10 psi off set at 7 psi
HKS T/timer (doesnt work though, needs rewiring)
Pivot Retractor Half Unit (Sleepy eye system)
Apexi EL boost gauge on pillar mount
Momo sports steering wheel
Phillips CD player
NISMO Gear knob
Razo Peddles
Formula one Tinted Windows
Full electrics
Digital Climate control
A/C, P/S, central locking.
also have the stock intercooler piping and intercooler supplied
12 MONTHS VIC REGO, JUST PAID. NO RWC SUPPLIED! 1ST OWNER SINCE HIT THE SHORES 2 YEARS AGO!
Serviced every 5000kms with Mobil 1 oil
running around 165-170rwkw without tune
email [email protected] as i dont check forums often!
PICTURES AT http://www.pbase.com/dion_180sx/inbox
EMAIL FOR OTHERS!!!!!
https://www.sau.com.au/forums/topic/35615-93-180sx-pearl-white/
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
