Any one have an idea or pictures of an intake pipe for 3540 in the factory location for an R33?
I will be running an air box, atm the only idea i have is to use 2 standard pipes cut down so they are 3" at both ends and have a 3" pipe inside to stop it from sucking closed.
https://www.sau.com.au/forums/topic/356173-3540-intake-pipe/
The stock inlet still sucks closed at 250kw with the 3 inch pipe in there, the bend collapses. Get an alloy 80mm one made and spray it stealth matt black.
The pipe is a bend, there is only 1-2" either end including the part where the hose clamp goes that does not have the metal pipe inside it.
The proof will be on the dyno, I haven't seen a stock one go over 250 but im sure they can. See how it goes I guess.
With a gt35 you should go 4 inch hardpipe imo, 80mm at the least if you are retaining the AFM.
