So it looks like this sits way out there in this forum as a very different look and drive. Pulls well for a FWD car, lots of torque at 3000 rpm.
Located lower North Shore, Sydney.
Will accept swap offers for Nissan 350GT, S15, WRX, and nice 2 seaters in general. Can spend a few K but not looking to part with much cash.
Car: 9N3 Polo GTI
Year: 2006
Travel: Appraching 32,000 kms
Options: None (Only Leather and sunroof available)
Asking: $20k, neg.
Rego: August? Need to check
Owners: The lady I bought it from was in her 50's and a nurse, I'm the second owner
Power / Engine
APR Stage 1, V2 chip (152ish KW)
Seat intake (Bigger Breathing Pipe to Airbox) & BMC Filter (Have original if you would prefer)
2.5" Dump pipe by Castle Hill Exhausts (Came recomended)
Forge FMIC (Have original if you would prefer)
Forge Splitter (Diverter Valve) - Partial Blow off option, have set to full plumb back
Forge TIP (Turbo Inlet Pipe) and Throttle Body hoses.
NGK Spark plugs (BKR6e?)
Dogbone engine mount
Handling: This car is tight on the roads, it is like a go-kart, completely different to stock
AP Coilovers
Whiteline Front and Rear Adjustable Sway bars
Whiteline rear Toe kit
Whiteline rear control arm bushes
Forge front strut brace
New front wheel strut bearings
Wheels:
Enkei's 17x8.
Mariangoli's, the nice ones (again, need to check) - Prob half life left
Gearbox
42DD and Verdict gear shift bushes
Martini gear box fluid
Braking: This needed to be addressed, stock brakes were not enough for normal street driving IMO
312mm front rotors
S3/TT Calipers / Carriers care of Fuzion
Currently running Bendix Ultimate pads, 500k old, have QFM pads as well
Braking is effortless and quiet
Exterior:
New (larger) Muffler tips
Stubby antenna
Blacked VW badges
Cupra (i think) front lip
Front Honeycomb grills (Mk5 GTI look)
Eyelids
Interior:
Dash lid then center console repainted to make all match
Minijack audio input cable (MP3 player)
Life:
This is the first car I've paid any attention to. The mods are all based on info from this forum, feel free to quiz the Polo boys about the mods.
I've grown interested in fluids and replace my oil every 5000 -7000kms with Castrol Edge 5w40, changed my gearbox oil to Redline and recently bled the brakes.
Feel free to call me to arrange a test drive.
0408 491 627
https://www.sau.com.au/forums/topic/356207-vw-polo-gti-2006-sydney/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
