I bought an r32 2 months ago and the blow off valve does not work. It has been plumbed back into the air intake after the AFM. I tried removing the plumbing from the BOV but nothing happens. Air continues to flutter back out of the pod filter. The BOV has a spring in it but the trumpet remains open no matter how hard or soft the BOV is set. I presume the guts have probably been blown out of it due to the 20 psi boost it previously ran. Just looking for an outside opinion. The BOV is a Greddy type RS I'm pretty sure.
https://www.sau.com.au/forums/topic/356222-bov-not-working/
+1 for it not being stuck open. You'd get no boost.
Sounds blocked off if it's fluttering. That is specifically how you get your flutter. Block it. Check for plate between as nismoid said. If it's adjustable is it adjusted too tight not allowing valve to open? Is gasket seated correctly. Like it's not all minced and bent effectively acting as a blocking plate or at least half blocking not allowing full release.
https://www.sau.com.au/forums/topic/356222-bov-not-working/#findComment-5700976
Had a quick look today and noticed that the breather hole on the BOV is sucking In air. Is it suppose to do this? If I block it with my finger the car let's out a backfire when reved. What are your thoughts ?
https://www.sau.com.au/forums/topic/356222-bov-not-working/#findComment-5701525
It's normal to suck in on idle. Basicaly anytime there's vacuum. I think. Then on throttle/boost it shuts until u let off and then it opens again.
But usually it's only slightly open on idle while it's sucking. Not completely wide open.
Again. Someone correct me if I've confused myself lol.
https://www.sau.com.au/forums/topic/356222-bov-not-working/#findComment-5701834
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
