Hey guys I've just bought an r32 and the low beams don't work, the parkers and high beams work fine.
So far I have checked the fuses, bulbs, pulled the switch apart and cleaned all the contacts, and have
tested to wiring using a multimeter.
I think the relay could be the problem cause when i turn the headlights on I don't hear a click but I'm
not sure if the parkers and high beams would still work if the relay was bad?
any ideas would be appreciated or if someone has a 32 near springwood that i could swap the relays
to check it that would be awesome.
cheers in advance
Corin
https://www.sau.com.au/forums/topic/356224-r32-headlight-problem/
My knowledge about Skyline lights is limited, if they are the dual filament type, it's possible the low beam filament have been burnt out (though would be strange having them both left and right at the same time)
cheers mate I will have a better look but at first glance I couldnt see any other relays that will fit, The weird thing is that the switch works to turn the parkers, and Ive pulled the switch apart and cleaned up all the contacts in there, does any know if the relay was bad would the parkers and high beams still work? cheers guys
the park lights are a seperate circuit to the high low beams.
which switch have you pulled apart?
the one on the dash cluster suround commonly fails.
but the high low dip stalk on the steering colum is very prone to ware. as are all 86-94 nissans. the contact arc up and creat an open circuit even when they are toutching. they are hard to clean up and not damage at the same time. they are carefully tensioned brass contacts and once bent out of shape are near imposible to fix.
ive never ever seen a relay fail in the head light circuit of a r32. but i havent worked on them all. so anythings possible.
Cheers mate
The switch I've pulled apart in the one in the cluster surround, I just cleaned up the contacts in there, I did this on my last r32 when one headlight was out and it fixed that.
I think I'll get a price for a new switch and relay. The only reason I suspect the relay is cause it doesn't make a click sound when I turn on the lights.
Thanks again
my wife is has this same problem with my R34 she just picked it up from nagoyamotors in sydney and she said the lows dont work but the highs do. idk about a clicking sound or not but im gonna aske her about it now.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
