I had a search on the forum and could not find anything relevant to this (at a glance)
The crux is that I need to install bonnet pins in my carbon bonnet (I would prefer the flush style one, however I understand that it would mean more material is removed.
Has anyone had experience with this? Or does anyone know if a panel beaters in vic that are knowledgeable in this area?
I would rather not stuff up my own bonnet and not be able to use it.
The two reasons that I am going this route (FYI) is that I would rather have the luxury of pins rather than a looped wire that I currently use for the track.
I also have the issues of the bonnet slightly moving around at high speeds...unfortunately with most things after market it does not fit like factory and I am out of adjustment.
I understand how carbon is weaved hence the concern. Also under the carbon layer there is fiberglass so it is obviously like most bonnets that are made this way...I am also concerned that the resin over the top of the carbon weaving will crack if not done correctly, leading to more cost and potentially some ugliness in the bonnet.
Cheers
Jez
https://www.sau.com.au/forums/topic/356267-bonnet-pins-in-a-carbon-bonnet/
Not really sure what your problem is. Most bonnet pins come with a plate for the pin to bear against, spreading the load. the plate is fairly thin, so you could try a thicker one to spread the load more.
Is it a road registered car? Pretty sure that bonnet pins are illegal on the road unless you use the flush mount ones. Why don't you want to use the flush ones? They distribute the load pretty well.
The problem is not the pins its cutting into the material...probably going the flush ones, road registered or not bonnet pins are usually ones last worry ;)
carbon fibre bonnets like yours are fibreglass with a top layer of CF to make it look pretty. even if it was ALL carbon its bonded with resin and will not affect anything if you cut holes in it for bonnet pins...
Pretty much, but that is all there is on the market for my car...
I just want to make sure that the resin wont crack and require repair. IE. there would be a specific drill bit that I should be using, IE. pitch etc etc...
its a quite simple job, ive put them in my carbon bonnet just the other week. . .
http://www.facebook....2b&id=683633649
i used a die grinder and notched it out slowly to get the right size, the pins actually have like a 5-8mm lip which allows it to cover the hole and screw into the bonnet with. . .
Edited by I8EE
wel if you get the flush ones you wont be using a drill bit will you.
If you get normals pins and need a hole you will be using a masonry bit. ie no rake. Otherwise the drill bit will bite in to the fibres and crack the resin... As for cutting out the shape for the flush ones you will be using a small grinder, preferably diamond coated however thats probably not within ur budget for the job. We get our grinding disks custom diamond coated. Any large holes should be done with again a diamond coated hole cutter. big sharp teeth may crack the material. have fun.
So in short you shoul be using diamond coated hole saw and cutting disk but if you cant get these any masonry bits for that job will do (normally bits of diamond or ceramic)
Carbon fibre/fibreglass is pretty easy to work with. just make sure you mask with tape around the area you're going to cut, helps from chipping/cracking the area you don't want to damage. Dremel or die grinder will be your best friend.
I'm installing my aerocatch bonnet pins on my gtr bonnet at the moment. Only have a die grinder and because the bonnet is aluminum, when it heats up it melts onto the die grinder, makes it a very long process.
  • 6 months later...
thats exactly what i did for aerocatches, dremel with the reinforce cutting wheel, cleaned it up with the sanding drum.
wear a mask, as the fiberglass / carbon dust isnt real good for you.
how bad is it for you, just did my bumpers a with a sanding disc an was covered in it without a mask on. :O
i did the gauge holes in my off-road race cars dash (alloy) took for ever till someone told me there are different die bits for alloy, changed the bit to a alloy one and bingo straight through
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
