Need to get oil and water lines for my highmount gt3082 on rb2530. As topic states, where is the best place to buy. Obviously there is a difference in quality out there in the kits I have come accross, ranging from about $80 up to nearly $400.
What have you guys used? tried searching cannot find answers.
Thanks
https://www.sau.com.au/forums/topic/356275-turbo-oilwater-lines/
I'd go and buy good second hand steel turbo water lines and banjo bolts from an SR20DET . They use either a Garrett bush or ball bearing center section which is externally same dimensions as your turbo . You buy new copper crush washers and bend/cut the steel lines so that they get far enough away from the turbos heat to enable the use of rubber hose to plumb to the engines water inlet and outlet . I've used EFI fuel hose in the past because its hardy re inforced so more durable than carby low pressure stuff .
Unless you get them pre made and cost effectively I think braided lines for water to 110C and 14-16 pounds pressure is over kill and more expensive than it needs to be .
A .
