my trailer will have an SAU "big gun" inside. We can't have Renew winning can we.
no indeed we cant. cant believe they had a rotary running in an evo. bizarre but clearly effective.
my silver R33 was about middle of the pack in my session, some great times and hungry for the next track day, sim cost to SAUs?
All good, Ive said all I needed to say about that. If it's the 33 then its a non issue.
Well Tiger you might have said ALL you needed to say but I Haven't. I WILL be bringing the Radical and thats THAT !!!,,,get Don to ring me (0419160561) if you like,,,but it seems RENEW have way to much to say about running this 3 event series.
I have run the Radical at tons of OUR events without a problem,,,ever. Our drivers don't have a problem with Ben or I,,,is it an issue with yours ???.
"Suggested my old boss who races a minetti in the same class as radicals and wests to a track day and the concerns I'm mentioning now are the sort of things that came up in the discussion".
Would that be Dennis or Scotty???.
Cheers
Neil.
yeah Duncan the track seems faster to me. I went 1sec quicker than I have before although I was on better tyres too (federals). The exit of 5 is larger, and they have fixed some of the ripple strips too.
Thanks Duncan.
Cheers
Neil.
Just stick the radical out with Ben in the Nascup and my R100 Sports Sedan. Brother was also considering bringing the PRB down. We can have the track to our self’s and get a clear run. Only cars under 800kg can apply LOL
Maybe we could keep the thread about the awesome day oth the 5th (excluding the first ever SAU track day bingle) and leave the possible entrants of the next trackday to another thread?
F stands for f**ked if I know. I was in that one. I can see Street, Club and Open in the rules: http://www.island.net.au/~rdavies/renew/2011%20Lap%20Battle%20Championship%20Regs%20-%20final%20draft.doc
Congrats on your time today, you were damn quick and I wish I could catch you lol
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
