Yo!!!!!!!!!!
Had heaps on. Sorry for the delay. I'll try to post up a few more shots tomorrow night, so stay tuned. I'll only be posting a handful of favs this time round. I'll leave you with this one as a teaser. ;)
I so hope the planets align and i make it down for your may track day guys. Looks like a damn fine day was had by all. :thumbsup:
Dates are here;
http://www.skylinesaustralia.com/forums/topic/331711-saunsw-club-events/page__view__findpost__p__5382776
I sent those dates to Andrew ages ago so you lot have no excuse
hardy har har.. Semis and less camber in the rear and possibly pads that are not made by EBC for the next round.. Very dissapointed at my 1st wakie
Im sure you can guess what we said when you went off at turn 1..... :D
Yo!!!!!!!!!!
hook me up old son
jenna wants a copy
Fatz, got your PM about the DVD details. Send $35 through to the club account and then shoot me a PM with your address details. When I dispatch the DVD's in about a week and a half - you'll get your's in the mail.
How easy is that!
Anybody else want to get in on the club DVD's? Just follow those instructions.
only the sweetest and kindest remarks from the great steveo..
howd you go geting home Dave? no probs with the de-oilcooler setup?
Yeah no dramas, started to get a bit of knock in 5th so i took it easy.. did an oil change to look for any metal shavings and it was clean so fingers crossed motor isnt on its way out..
Cant afford to stuff around fixing the car.. So time to hang up the racing boots for this year
when you say knonck...do you mean on the powerFC or a regular noise from the engine directly? If its the former just get it to a workshop, if its the latter start saving
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
