Wakie Track Day Wrap-Up Thread - 5 March 2011
GoldZilla
 Share
kinks yea still got the red top it in (bought it cause i new it went well from my previouse drift days)
jap dash (proabaly swap that out)
its entered in the PF 13's for 1300 bux challenge as well
and the shitbox rally
jap dash is great, fuel gauge never worked that well tho (wrong sender). send me PM when you post pics + vids of it, i'd love to see it in action.
still got an RB25 turbo in it? and locked diff? good times that :)
id laugh if you got pulled over for having a profanity on your door fatz
i'd laugh at the reaction of the cop after talking to fatz. the profanity on the door would be nothing compared with the driver :)
I just got the first disk of pic and Dave there is a Classic one of you just finished playing in the dirt somewhere. Huge cloud of dust behind your car clear as day. Classic!
even the cop thought it was funny
just doing his job
i let down the old dudes wheels in retaliation
haveent seen him since, guess a wheelchair with flat tyres is a prick to use
LMFAO
Glad the disks are making their way out.
What tyres are you running? There is a huge difference of a GTR on street tyres vs Semis. This is especially true if you have bumped up the power levels. And, No the GTR won't just go where you steer it. Don't listen to the 2wd haters out there calling you a cheater. You still have to drive it - and can be a bit harder if you go in too hard cause the power to the fronts can cause understeer.
Give it a few track days and you'll find your times getting better and better as you learn to drive the GTR the way it wants. Took me a few trips to Wakie and I'm still learning.
 Share
    • FWIW, I've always found Toyota A/Cs to be much colder than Nissan ones. Even that 2024 Nissan X-Trail (that VW Australia lent to me), the A/C isn't as cold as other base model Toyota Corollas/Camrys, etc. Maybe Toyota A/C compressors are superior?
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
