oh ouch! you should never let your children leave unless you are ready for anything to happen to them.
I still don't know what happened to zerasa (ne huge1), it came to 1 track day then disappeared
kinks yea still got the red top it in (bought it cause i new it went well from my previouse drift days)
jap dash (proabaly swap that out)
its entered in the PF 13's for 1300 bux challenge as well
and the shitbox rally
jap dash is great, fuel gauge never worked that well tho (wrong sender). send me PM when you post pics + vids of it, i'd love to see it in action.
still got an RB25 turbo in it? and locked diff? good times that :)
id laugh if you got pulled over for having a profanity on your door fatz
i'd laugh at the reaction of the cop after talking to fatz. the profanity on the door would be nothing compared with the driver :)
even the cop thought it was funny
just doing his job
i let down the old dudes wheels in retaliation
haveent seen him since, guess a wheelchair with flat tyres is a prick to use
LMFAO
Glad the disks are making their way out.
What tyres are you running? There is a huge difference of a GTR on street tyres vs Semis. This is especially true if you have bumped up the power levels. And, No the GTR won't just go where you steer it. Don't listen to the 2wd haters out there calling you a cheater. You still have to drive it - and can be a bit harder if you go in too hard cause the power to the fronts can cause understeer.
Give it a few track days and you'll find your times getting better and better as you learn to drive the GTR the way it wants. Took me a few trips to Wakie and I'm still learning.
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
