Haha no not retreads.
Fair enough if you have spent the dollars on a new setup...what are they???? :)
Weds SA90 :)
They just off getting some colour change love!
And Snowys old Tien's to go in as well.
  • Replies 136
Posted Images
LOTS of dish with the offset I have (there is a pic on my FB mobile uploads if you wanna see from a couple months ago) :)
I hate TE37's TBH. Every one has them! Took 8-9 months to find a set of SA90's (Via everyone friend @ Import Monster). Was looking for them before i even owned a GTR lol.
First track day for me, is a MotoX style helmet ok? also anything else I need to make sure to bring? so I don't miss out after a 2.5 hour drive :P
Can I renew cams license on the day?
-Leigh
-Leigh
moto helmet is fine. Wipe the mud off first :)
Bring extra pads, brake fluid, oil, tools, jack, fire extiguisher mounted well!
Jerry can of fuel. You'll prob go through more than half a tank.
Can't do cams at winton I don't think.
Thanks for the quick reply :thumbsup: will try and organize all this.
Should I be overfilling my engine a bit with oil? (only just had 100k service at racepace so most things should be ok)
Can anyone tell me more info about renewing CAMS?
You may have left it late to renew CAMS, it generally takes 10 days to fully process. You won't be able to renew on the day, though check with wrx club. [email protected]
Prob have to sign up for AASA if you can't get CAMS through...You can do that at Winton. Or drop into CAMS in caulfield? Though that may cost extra $$$.
The motoX helmet will need AS1698 or greater sticker on it (SNELL or FIA as well).
If you want cams and have time go into their office in malvern (i think it's malvern)
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
