Here is my 2001 R34 GTR V-spec 2.
I've owned it for about a year and a half now. Its come a long way from since i bought it back in 09. The car use to have 350kw@wheels on the standard engine with tomei turbo's, v-cam, e85 etc. As usual, the power bug bites so i decided to have a big motor built. I chose Powertune Australia to build it because of the knowlegde and tech support they give when questioned. I've been to other workshops before but they didnt provide the extra edge/support i looked for in a workshop.
Engine :
Head -
Brian Crower custom Powertune spec cams
Brian Crower springs
Brian Crower valves
Brian Crower titanium retainers
Brian Crower adjustable cam gears
Powertune ported head
Block -
Brian Crower 2.8litre billet crank
Brian Crower rods
CP Pistons
Turbo -
Precision PT7175 Turbo (975HP)
2x Tial 38mm external wastegates
Powertune Exhaust manifold
Fuel System -
Powertune twin intank fuel pump kit
I.D. 2000cc injectors
Aeromotive fuel reg
Sard fuel rail
Misc -
Tomei oil pump
High Octane extended oil sump
Earls lines and fittings
Blitz air filter
ARC air separator
Greddy aluminium radiator
Greddy aluminium pulleys
Plazmaman drag intercooler
Mine's cam cover baffles
Garage Defend cf cooling panel
Kansai front strut brace
ARP head studs
Metal head gasket
ATI Balancer
Gates Racing timing belt
Haltech platinum pro sport ecu
Splitfire coilpacks
Optima dry cell battery
Transmission :
Standard Getrag 6 Speed
Ogura Quad plate clutch
Wheels :
Track - AME Tracer (grey) 18 x 10 +15 on Mickey Thompson ET Street radials
Street - TE37 (black) 19 x 9.5 +12 on Bridgstone Potenzas
Interior / Exterior :
Nismo MFD
Nismo B-pillar garnish
Nismo oil cap
Nismo gear knob
Nismo floor mats
Nismo 320kph cluster
Nismo GT tail lights
Bodyform copied nismo side skirts
Bodyform copied nismo rear pods
More pics of the build will be uploaded in the next few days.
  • Replies 296
The car got a run-in tune on 28/2/11. Drove it around town for 1000kms which wasnt too fun being restricted to 6000rpm.
Finally got it run in and lightly tuned on 1/3/11. we had trouble keeping it strapped to the dyno under boost. but here it is for now. will be upping it again soon. currently on 35psi. we needed 3ppl sitting in the boot and 2 ppl in the the car to keep the car partially down
I drove the car to WSID on 2/3/11 the day after the 602kw tune. At the top of the track the car felt unstable at 230kph. So this morning i went to Heasman steering to get it checked out and this is how far off my wheel alignment settings were when i raced last night. Still running all the stock arms so camber still couldnt be taken out of the front or rear. but it goes straight now atleast. =)
http://www.youtube.com/watch?v=H7a2kboctz0
Powercruise 2011! 4/3/11 I drove it to the event on friday, saturday and sunday and ran around the track racing anything and everything that wanted to line up. The car has proven its reliable and able to crush v8's / tubbed / supercharged cars. Nothing broke down, nothing overheated. I was out there on nearly every chance i had. was a blast and very fun event. Not bad for a car thats just been completed. =)
awsome....any video of your beast at power cruz
What do you think those last videos were??? lol
A credit to all involved with this build, top shelf stuff!
Performed flawless all weekend, was great to watch.
Please tell me you let the capri win in the final? There was no doubt that the gtr had it the whole race, except that very slow change into third :)
That is one damm impressive beast you have there Anthony. Please please get some better photos up of the engine bay. It looks killer
lol, will do.
those last ones are all from powercruise.
thank u! lol.
yea from 2nd gear i smashed it into 5th missing 3rd. then i pulled it out of 5th and smashed it into 3rd. i had alot of airspace on him just before that happened. its all on the incar camera. hahahaha all good. was a fun event that i'd love to do again.
WOW
big dollar spend GTR, that actually geting USED.... now this is rare and nothing is blowing up either :)
i looked at the videos, "you photos needs a bit of work mate"
and thought to my self god he must be running a Dog box or something and read
Transmission :
how on earth does the standard Getrag keep up with this much POWER , "i must abuse mine a bit more now"
if you can build this car then you can get a guy to take some nice photos of that engine bay
WOW
Transmission :
lol, car isnt done yet so no use in taking high res pics.
Awesome work!! Must be a great feeling to have so much kw's rushing through the blood :) any plans for the box? Is it 3rd gear that u start to annihilate everyone or u actually get into fourth?? Lol
yea, its about 3rd gear that i start passing. nah no plans for the box just yet. i think i gotta learn how to shift into 3rd a little slower and itll be ok,
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
