nice engine build. I would definitely be looking at upgrading the suspension. it has lots of movement under power (to be expected with that much) but it also moves around a lot more than it should under brakes. if it's still got the stock gear in it there is a good chance it's stuffed by now. no need to go nuts but some upgraded shocks and springs will do wonders for it.
  • Replies 296
just upgraded the brakes to some endless pads.
thanx guys
great car make thing sounds unreal was great to watch in real life.. how were you taking off at the start? are you dumping it or just letting the power do its work
taking off on the 2step with 25psi at 6000rpm and playing with it off first gear.
Great build ! and nice to see it being used like it is ment ;)
WOW
big dollar spend GTR, that actually geting USED.... now this is rare and nothing is blowing up either :)
i looked at the videos, "you photos needs a bit of work mate"
and thought to my self god he must be running a Dog box or something and read
Transmission :
Standard Getrag 6 Speed
Ogura Quad plate clutch
how on earth does the standard Getrag keep up with this much POWER , "i must abuse mine a bit more now"
if you can build this car then you can get a guy to take some nice photos of that engine bay
Why wouldnt the standard Getrag keep up with 800 whp ? isnt it the same V160/V161 as in the Supra ? and there are bunch of Supras with stock getrag gearboxes running 8 second 1/4 miles and with 1000-1500whp even the SW/ Boost logic supra has a stock V160 Getrag gearbox running 7.91 @ 189 mph in the 1/4 mile and cutting 1.26 60ft
sry for the offtopic op
Shock loading from launching an AWD car, twists the gearbox casing causing the case to crack. A supra will get some wheel spin, and at least some wheel spin reduces torque twisting stresses. Flexing and cracking of the gearbox casing, and also flexing of internal thrust surfaces causes internal parts to go out of alignment when under load. Once that happens its all downhill from there.
Look up the RIPS BORG R33 GTR build on gtr.co.uk. They post up pictures of the carnage after a good launch destroys an r34 getrag that had a PPG gearset.
My mind still boggles at the thought that these supra drag cars are using "stock" gearboxes too. I think some people's interpertation of stock and others differ somewhat, and the only stock parts might well be the casing and a few bearings. Nobody that races cars that run 7's tells the world precicely how they did it.. so sure, its all stock!
you talk of Supra getting some wheelspin ? but as i said they are cutting 1.25-1.40 60ft that means they are hooking pretty good ! and yes they all say that hey are using a completely stock from factory gearbox, only time ive seen a Supra split a gearbox casing was Saad´s Supra when he was running low 8´s
Btw here is the top list for 6 speed supra, all of them with a completely stock from factory getrag v160 gearbox / internals untouched
1. [email protected] SW/Boost Logic. 6 speed, 3.4L, BL GT55-91, NOS, AEM (highest mph 189.7)
2. 8.29@174 Saad N Saad Valero In The Zone, 6 speed, ProEFI, 55-91, 150shot
3. [email protected] Ryan Woon. WOTM 6 speed, 3.4L stroker, GT55-91, single fogger, 3330lbs
4. 8.38@174 Darin Dichiara 6-speed, 3300 lbs, GT47-88R, 3.0L + nitrous motec m600 28x10.5 ET drags
5. 8.41@ 179 Rich Homer 3.4, 47-88, direct port, motec, tilton http://www.youtube.c...h?v=yirVDXbUR5s
6. [email protected] SW/Chris Johnson/Boostlogic. 6 speed, 3.4L stroker, BL GT55-91 , 3650lbs
sry again for the off topic op
Edited by R32GTR/Iceland
All very impressive mate but that doesnt alter the fact that the gtr has an issue with the gertrag box.
For the few years i've been involved in the skyline scene its been common knowledge that there are issues when they are leaned on hard.
There is one down at Dan's workship as we speak with this very problem.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
