  • Replies 296
Just incase you guys wanted to know how fuel efficient a 600kw gtr is on the street. i did a simple test. fueled it up then cruised it around town till it was nearly empty. i think i could of reach 190km's if i waited for the fuel light to come on.
shit and i thort mine was bad for getting 250 kms.
i think i should stop complaining now lol
its about 25litres per 100km's so its quite good. a mercedes ml63 or bmw x6 tt is the same.
Makes a strong argument for running a water/meth injection setup and normal bp98. Though for a 600kw toy fuel economy doesnt really enter into it. I know someone that uses mixed BP98/Martini race fuel mix in his 600kw street car. You can't put a price tag on fun if you have a surplus income.
Some parts arrived yesterday. =)
Chrome door handles
Before...
After...
Nismo rear spoiler flap
Nismo socks
Nismo spoiler fitted
Tein Bonnet damper
Tein bonnet dampers fitted
Is that VHT wrinkle paint i see? Amazing car BTW
Small update : Powertune re-tuned the car yesterday. It started at 602kw then kept floating around 630kw except the car felt like it kept making more than what it was showing on the dyno, so the only other option was to take it for a power run down at JEM. Adam and the Powertune boys got the car strapped down on JEM's Mainline dyno and gave it 2 runs that showed 703kw both times.
I will run the car down the track again soon.
As you said you cruised it, and it's a turbo car, you really should be able to get better then standard fuel economy. While cruising it, you're making the motor make the same power as a stocker cruised... This should use the same fuel as a stocker. I'd be having serious talks with the tuner. If you cruise it too much I see washed bores occurring...
errr.... the word cruising in my terms is cracking gate a more than a few times hitting 9000rpm.
great result on the retune!!!!!!!!!!
you going to go for 1000hp??
hahaha your definition of cruising is brilliant as if you wouldnt crack gate!!! pffft staying off boost thats only for when you are stopped
the car is still in the early development stages so yes it will eventually be wound up again.
lol
That's not cruising around town.
Cruising around town would be sedate driving not unleashing 600kw on.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
