  • Replies 296
nice one mate. you will love the hollinger, best money you'll spend on the car. bet you were impressed with how compact and light they are for such a stout 6 speed sequential box? they are a better thing in every way. better gears, better engagement, sequential, better casing and on and on. well worth the $20odd thou. espcially considering doing a full house gearset upgrade in a stock housing these days can run to $13-$15K by the time you do all the little upgrades and have it all assembled. no such drama with the hollinger and they are so nice to drive. :)
lol, thanx guys =)
what compression BC stroker kit are you using?
i'm unsure. powertune know more about it than i do
hahahaha i hope your not wrong. =)
I've heard mixed reports about the hollinger. The good is they are bullet proof, ultra fast to shift etc.
The bad was (as I was told from someone else with a hollinger and 800+hp), the car lost what street manners it had left. Thats fine if you use the car as a toy that you occasionally go for a blast on the street or race track. But you cant drive your mum to the shops in it anymore. Based on what you said the cars fuel consumption is though, Im guessing its a toy so you will probably love it.
As long as you remember not to come to a complete stop, at an intersection, in 3rd gear, with cars waiting to turn behind you while you attempt to select lower gear but you can not. So always when downshifting, car needs to be moving at least a little. That is the only downside on the road, but than again there are too many positives to worry about any negative.
Enjoy the box. Once you setup your quick shift, up-shifting is a pleasure.
:thumbsup:
yeah they are definitely not that street happy. I mean you can't just cruise off and whack it into 5th or 6th and cruise. need to shift up and down the gears through every gear which can be tough if crusing in 4th and suddenly have to stop and quickly row back 3 gears. but like most things you would get used to dealing with it. also sucks in carparts as you sit there trying to grab reverse which can be a pain as you have to go into 1st, then into neutral, then into reverse. try doing it 3 times quickly in a 3 point parking manoeuvre!
but the joy under full power on the circuit makes them well worth it.
LOL Pete! Plenty died after 1 run, some lasted two :D
Was good to see this car in person. Gearchanges were just silly, that alone is worth 20k!
Needs some work round the launches to get outta the hole better and it'll be ridiculously fast!
Even i was a casualty on my last run, but it was expected :D
I remeber your car, what happen to it?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
