:thanks:
After reading this thread I had to ask my misses if she could get me a towel!!!!!!!
Now that is GTR porn
:rofl:
How does the car stop compared to the factory brakes?
its like comparing day and night, theres so much difference. it feels like it can stop on a dime. i didnt realise how shit the standard ones were until now.
:yes:
Nice...are these ford territory turbo calipers ?
lol, nah, these are the brembo gt kit.
:D
Edited by AH_HUH
  • Replies 296
As you said you cruised it, and it's a turbo car, you really should be able to get better then standard fuel economy. While cruising it, you're making the motor make the same power as a stocker cruised... This should use the same fuel as a stocker. I'd be having serious talks with the tuner. If you cruise it too much I see washed bores occurring...
Mate your never going to get 500 or so kms out of a tuned GTR i dont care how you drive it. My old car would be lucky to get 300 odd kms around town.
btw nice car mate sounds tuff!
I don't see why not, at cruise load you would be lucky to be making 100hp, probably closer to 80 or 90hp. Shouldn't be using a lot of fuel unless you put your boot into it.
But I digress, Anthony did say his definition of cruising involved boosting it hard, which is what this car does best :D As if anyone could just putt around in a 950hp 2.8L GTR :P
Edited by Hanaldo
Who cares what mileage you get.. If you can afford to produce a car like that and exclusively run it on E85 then I am pretty sure you wouldn't care how bad the fuel economy is.
You can't expect to maintain a very healthy fuel consumption rate if you drastically increase your performance levels thats pretty much a given.
Shift light in the cluster looks mint, very nicely integrated
Does on the highway count?
  • 3 weeks later...
Yeah highway counts. I was making 310rwkw out of my R33 and dont think I ever saw 500km to a tank. I used to think they were good when kept off boost and just cruised around but this was short lived when the car came from the workshop. You might say I had a bad tune, but Ill tell you that 3 different, well respected tuners have tuned the car on different occasions.
p.s i think we are getting a little off topic, Loving this build up, keep the pics/vids coming!
  • 4 weeks later...
was there a reason why u didnt just replace your standard dash with the haltech unit?
cant imagine it would be easy to look at when this beast gets going (veiw for the passenger will be good tho)
very very neat job anyway
keep the updates coming
the reason it isn't mounted where the original cluster is because i wouldnt have turn indicator lights, fuel guage and a few other things. plus it would stand out too much to the police at night. the main reason i'm using the unit is to view the ethanol content in the fuel and monitor a few other things while the car is staitionary. but it does give the passenger something to look at while we are on the move.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
