  • Replies 296
so problem will be solved by getting proper sized rods
Well it's either you use standard length like the HKS 2.8 kit does or 119.5 mm (2 mm shorter) like the Tomei does. It's all about where your pin sits.
Either way, when stroking your rod to stroke ratio is going to fall, but really, 26's ain't the best from factory. It means a little bit more wear and harder on the pin, however, there are advantages also.
  • 3 weeks later...
I noticed that you ran a pod filter in the engine bay in the early days with the car, and have since revised it so the filter is in front of the left front wheel.
Do you have any pictures that more closely show you relocated turbo air intake?
Did you have any concerns with water on the filter in the low location from wet weather driving, or do you have a rain shield around it?
  • 1 month later...
Hey Guys,
I am trying to get in contact with Anthony, the owner of GTRB28 but he hasnt been on AUS for about a year. Anyone know how I can get in contact with him?
yeah its in kemps project 34 now, running low boost (30psi low) until he changes gearbox etc. he was going to build an elephant package so just bought it as the owner was selling for bigger better things.
no doubt powertune could build another if youre serious.
kemp doesnt work at powertune either., unless recently employed lol.
  • 10 months later...
Hi AH_HUH, I went hunting through the thread and can't find a dyno plot for the RB28/PT7175 combo - what was the most power it made, and how was lag with it... if you don't mind sharing?
Do you reckon it needed much more than 5000rpm for full boost? Cheers :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
