  • Replies 296
Just incase you guys wanted to know how fuel efficient a 600kw gtr is on the street. i did a simple test. fueled it up then cruised it around town till it was nearly empty. i think i could of reach 190km's if i waited for the fuel light to come on.
shit and i thort mine was bad for getting 250 kms.
i think i should stop complaining now lol
its about 25litres per 100km's so its quite good. a mercedes ml63 or bmw x6 tt is the same.
Makes a strong argument for running a water/meth injection setup and normal bp98. Though for a 600kw toy fuel economy doesnt really enter into it. I know someone that uses mixed BP98/Martini race fuel mix in his 600kw street car. You can't put a price tag on fun if you have a surplus income.
Some parts arrived yesterday. =)
Chrome door handles
Before...
After...
Nismo rear spoiler flap
Nismo socks
Nismo spoiler fitted
Tein Bonnet damper
Tein bonnet dampers fitted
Is that VHT wrinkle paint i see? Amazing car BTW
Small update : Powertune re-tuned the car yesterday. It started at 602kw then kept floating around 630kw except the car felt like it kept making more than what it was showing on the dyno, so the only other option was to take it for a power run down at JEM. Adam and the Powertune boys got the car strapped down on JEM's Mainline dyno and gave it 2 runs that showed 703kw both times.
I will run the car down the track again soon.
As you said you cruised it, and it's a turbo car, you really should be able to get better then standard fuel economy. While cruising it, you're making the motor make the same power as a stocker cruised... This should use the same fuel as a stocker. I'd be having serious talks with the tuner. If you cruise it too much I see washed bores occurring...
errr.... the word cruising in my terms is cracking gate a more than a few times hitting 9000rpm.
great result on the retune!!!!!!!!!!
you going to go for 1000hp??
hahaha your definition of cruising is brilliant as if you wouldnt crack gate!!! pffft staying off boost thats only for when you are stopped
the car is still in the early development stages so yes it will eventually be wound up again.
lol
That's not cruising around town.
Cruising around town would be sedate driving not unleashing 600kw on.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
