  • Replies 296
As you said you cruised it, and it's a turbo car, you really should be able to get better then standard fuel economy. While cruising it, you're making the motor make the same power as a stocker cruised... This should use the same fuel as a stocker. I'd be having serious talks with the tuner. If you cruise it too much I see washed bores occurring...
That's incorrect. The Powertune R34 does not run stock cams.
Some parts arrived yesterday. =)
Nismo socks
Hahah this is the shit right here :D seriously though... why did you buy them? LOL
Good work on the interior door handles too, were they a factory option or something? Love it.
I'm not sure if I missed it or not but what suspension are you running in this?
  • 3 weeks later...
nismo socks adds more traction
the door handles are off another car
i was running stock suspension at powercruise
lol mr chams cant wait to race it my self lol hopefully it will go to cootamundra and we can see if 704kw or 721kws is faster lol ha ha ha
Engine specs are same as mine but the turbo and cams are a PJ S13 Spec and the car runs @ 45 psi of boost to make 704kws as we only run @ 32 psi to make 721kws same shop same dyno people .......!!!!!!!!
Edited by qsrgtr
only run @ 32 psi to make 721kwsworship.gifworship.gifworship.gif same shop same dyno people .......!!!!!!!!nyaanyaa.gifrolleyes.gifnyaanyaa.gifrolleyes.gifnyaanyaa.gifrolleyes.gif
We have run a 9.63@144mphaction-smiley-069.gifaction-smiley-069.gifaction-smiley-069.gif but
the r34 has only gone 10.7whistling.gifwhistling.gifwhistling.gif at the best pass
Edited by qsrgtr
I can't wait to race this R34
sounds like fun
congratulations man, i'll be out there again soon.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
