  • Replies 296
Engine specs are same as mine but the turbo and cams are a PJ S13 Spec and the car runs @ 45 psi of boost to make 704kws as we
only run @ 32 psi to make 721kwsworship.gifworship.gifworship.gif same shop same dyno people .......!!!!!!!!nyaanyaa.gifrolleyes.gifnyaanyaa.gifrolleyes.gifnyaanyaa.gifrolleyes.gif
We have run a 9.63@144mphaction-smiley-069.gifaction-smiley-069.gifaction-smiley-069.gif but
the r34 has only gone 10.7whistling.gifwhistling.gifwhistling.gif at the best pass
Hey what car you got???
Nice effort on the Rigolli dyno today!!! Sounded nuts :thumbsup:
Pretty sure that dyno is low reading!!!for sure.
the car wheel spinned on the dyno, u could see it made a difference when a couple of guys jumped in the boot. oh well too bad so sad.
I hope so, I want to hear that thing on a launch aswel.
Actually, any tough GTR on a launch is just fine by me hahaha
Wouldnt JUN be at the end of year one instead of this one?
Any car can enter this one other wise no GTR's would be able to enter to make it fair
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
