  • Replies 296
nice one mate. you will love the hollinger, best money you'll spend on the car. bet you were impressed with how compact and light they are for such a stout 6 speed sequential box? they are a better thing in every way. better gears, better engagement, sequential, better casing and on and on. well worth the $20odd thou. espcially considering doing a full house gearset upgrade in a stock housing these days can run to $13-$15K by the time you do all the little upgrades and have it all assembled. no such drama with the hollinger and they are so nice to drive. :)
lol, thanx guys =)
what compression BC stroker kit are you using?
i'm unsure. powertune know more about it than i do
hahahaha i hope your not wrong. =)
I've heard mixed reports about the hollinger. The good is they are bullet proof, ultra fast to shift etc.
The bad was (as I was told from someone else with a hollinger and 800+hp), the car lost what street manners it had left. Thats fine if you use the car as a toy that you occasionally go for a blast on the street or race track. But you cant drive your mum to the shops in it anymore. Based on what you said the cars fuel consumption is though, Im guessing its a toy so you will probably love it.
As long as you remember not to come to a complete stop, at an intersection, in 3rd gear, with cars waiting to turn behind you while you attempt to select lower gear but you can not. So always when downshifting, car needs to be moving at least a little. That is the only downside on the road, but than again there are too many positives to worry about any negative.
Enjoy the box. Once you setup your quick shift, up-shifting is a pleasure.
:thumbsup:
yeah they are definitely not that street happy. I mean you can't just cruise off and whack it into 5th or 6th and cruise. need to shift up and down the gears through every gear which can be tough if crusing in 4th and suddenly have to stop and quickly row back 3 gears. but like most things you would get used to dealing with it. also sucks in carparts as you sit there trying to grab reverse which can be a pain as you have to go into 1st, then into neutral, then into reverse. try doing it 3 times quickly in a 3 point parking manoeuvre!
but the joy under full power on the circuit makes them well worth it.
LOL Pete! Plenty died after 1 run, some lasted two :D
Was good to see this car in person. Gearchanges were just silly, that alone is worth 20k!
Needs some work round the launches to get outta the hole better and it'll be ridiculously fast!
Even i was a casualty on my last run, but it was expected :D
I remeber your car, what happen to it?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
