  • 5 months later...
  • Replies 296
So to bring the thread back to life, i sent the car down to speedfab.com.au in smithfield for some custom fabrication work.
The rear diffuser is about 80% complete with the transmission cooler mounted :
A billet peice was made to retain the factory jacking point
Diffuser air guide cutout for transmission cooler
Custom made hicas bar delete
Thats great!
Did they make up templates so they can fab up a few more of those diffusers?
I've been considering something like this to allow a second rear mount radiator to be run, so I can keep engine temps at 80 degrees regardless of how exuberant I might be driving...
Thats great!
yea they had templates but only rough ones. most of it was custom made as they went. but u can send them an email and they'll hook u up.
how much does it weigh compared to a factory carbon one?
it weighs about 2kg's heavier than the factory carbon one
Rob and Anthony do top work, had my car there when your car was there.
I had to stay for an extra 5 mins while Rob was moving your car outside, sounds mental as always ;)
your car was the white r33? if it is, it looks very clean.
Wow, that's incredibly impressive work.
This thread is never a dull read :thumbsup:
use to see this around my area all the time, it sounds even more angry in person lol
looking choice as anthony.
what did u do with the oem diffuser?
i'm putting it away in storage
looks sweet as
Will you be at powercruise coming up 3rd march ! ?
I hope you are again , this car MADE powercruise last year.
yes, i have a garage again this year
Was there reasoning behind why they didnt run the diffuser all the way to the side, rear spats that are beind the wheels. Amazing fabrication...some goods craftsman out there!
to use the factory mounting points
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
