Hey guys,
Only had this car for a little while but im planning a trip to japan and cant really afford to keep this anymore.
at the moment its EOI because im in no rush to sell, its just preferable to have the extra cash for the trip.
Most of you would know this is Simon's old r32, i've started neatening things up since i got it,
Before i got it it had:
-Buzz spec Struts all round
-Rack spacers
-RB25det with RB20 ecu tuned for 12psi. Makes 210 rwkw.
-fresh respray done a year ago in Mazda metallic red (as seen on RX8) looks brilliant in the sun.
-handflared guards. will accept good sized wheels with no issues. used to run XD9's in 17X9.5 +15 all round
-straight as body and chassis rails
-HD clutch
-MINT gearbox
-Chassis has around 80,000 kms and engine about the same
-3 inch exhaust
-many bushes replaced
-18inch starcorps
-mp3 player
-brand new battery
-A/c removed
Since i have had it, i have:
-Replaced leaking shifter boot
-Installed kenwood DVD headunit with 7inch flip out screen
-Installed bosch 040 fuel pump
-Replaced rear tyres
-Installed el cheapo boost gauge
-Repaired and installed various interior trims
-Replaced drivers power window master switch
-Changed gearbox fluid
-Made metal airbox
Asking price is $10,000, it was originally for sale for $9,500, but with all i have spent i think it's a fair price.
Also interested in trades for a cheaper car (Around 4g value) with cash my way.
Car is really tight, no noises while driving, runs great, quick car.
Pictars!
Feel free to post her, pm me or text me on 0405 317 979
https://www.sau.com.au/forums/topic/356329-sa-eoi-rb25-r32-4-door-legal/
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
