engine now available for viewing.
complete standard rb25det package minus turbo from a s1 r33.
purchased and installed by justjap on 11/12/09 (1 year 2 months ago) and has since put 31,000km on the engine. I also have the purchase and install receipt from justjap.
includes throttle body, intake manifold, injectors, rail, reg, complete running motor with accessories; p/s, alternator, exhaust manifold, engine mounts, coilpacks and ignitor, loom and standard ECU. rb25 gearbox with no crunches, shifts nice and smooth, no issues. includes a short shifter, box mount, clutch slave cylinder, heavy duty clutch of some sort, will be inspected when engine is removed.
Engine runs fine with no issues, blows no smoke. Can be seen running before it is removed from the car.
$2800 with everything
$1600 without gearbox
if any more info is required, can contact by pm or sms 0416 129 811.
located in wollongong.
https://www.sau.com.au/forums/topic/356342-complete-rb25det-package-gearbox/
  • 3 weeks later...
PRICE DROP
$2700 complete
$1450 excluding gearbox
Turbo was just sold off the car and will come off tomorrow, if anyone wants to get in and see this engine running before its too late
get at me on 0416 129 811 asap.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
