Looking at the photos I first though "wonder why they wrote that one off?".. but then after looking at the rear wheel in the last photo I think I know why... as for that guy's comments.. don't stress.. only 1 wanker out of the lot ain't a bad ratio...
https://www.sau.com.au/forums/topic/35638-the-memories/#findComment-711431
Oh my gord! I think I am gonna cry.
Hope you're alright, that's the main thing.
Now there are only 1,000,001 R33's in WA.
Hope you are covered by insurance etc....Keep your chin up.....go out and get another one, in the meantime there are plenty of skyliners you can hitch a ride with south of the river :D
https://www.sau.com.au/forums/topic/35638-the-memories/#findComment-711462
9,800!?!
that's pretty spensive! easily 6 grands worth of damage there.
guess that there's not enough 33s around for caryard at the moment....
*grade 4.5 nissan skyline 2.5L turbo
fast car, beautifully presented. one lady owner. aftermatket rims and bodykit, from $24,000
call Skipper Mitsubishi*
https://www.sau.com.au/forums/topic/35638-the-memories/#findComment-711859
it's funny how much damage the fence has done to the rear panels. like little scales. looks more like how I'd imagine fibreglass panels to crumple under normal-to-panl compression load like that.
on a slightly off topic note - some nimrod has advertised an R33 in the paper for the last three or so weeks with a "one lady owner comment". go figure. good test of how gullible people really are I guess.
https://www.sau.com.au/forums/topic/35638-the-memories/#findComment-711961
9,800!?!
Skippers are the worst sharks in the industry. And thats saying something. Took my GTR in to possibly trade on a Liberty B4. They had a clapped out R32 GTR for sale for $38,000. It was really bad condition the wiring under the bonnet was butchered. When I asked them how much they would give me as a trade they said $19,000. For a much better condition car. Scumbags.
https://www.sau.com.au/forums/topic/35638-the-memories/#findComment-712780
  • 3 weeks later...
" one lady owner"
The rest were Japanese male drifters...
Cheers
Ken
https://www.sau.com.au/forums/topic/35638-the-memories/#findComment-737581
yeah i worked for skippers for two years as did my ex .... all i can say after what we did to some cars .... hmmmm buyer beware ..... but to tell you the truth - skippers is no different to any other caryard!
https://www.sau.com.au/forums/topic/35638-the-memories/#findComment-737722
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
